GrimmReaperNL Posted August 15, 2022 Posted August 15, 2022 Hi there, I was showing my aquacomputer d5 next pump speed on my sensor panel. 'all of a sudden' it's not longer showing up. I have a Quadro on the same usb connection over a Hubb7, and the quadro is showing fan speeds and a temperature sensor. I've attached the aquacomputer dump. Hopefully someone can help me out. aquacomputerdump.txt 1 Quote
Fiery Posted August 16, 2022 Posted August 16, 2022 18 hours ago, GrimmReaperNL said: Hi there, I was showing my aquacomputer d5 next pump speed on my sensor panel. 'all of a sudden' it's not longer showing up. I have a Quadro on the same usb connection over a Hubb7, and the quadro is showing fan speeds and a temperature sensor. I've attached the aquacomputer dump. Hopefully someone can help me out. aquacomputerdump.txt 13.16 kB · 2 downloads Thank you! We've fixed sensor support for D5 Next with its latest firmware update. Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let us know how it works 1 Quote
GrimmReaperNL Posted August 16, 2022 Author Posted August 16, 2022 D5 next items show up in the sensor panel manager. Thanks for the quick turn around. Quote
Grifter Posted August 29, 2022 Posted August 29, 2022 Thanks guys, I updated my D5 Next firmware 3 days ago and wondered, why 3 of 5 stats on my sensorpanel where dead afterwards. Now it works again. Quote
