Hello, can I display aida extreme on 2 monitors?
i have a 7 inch pc and a monitor on which i want to display the sensor panel in different resolutions. Is that possible ? it should not be displayed on my main monitor. I thank you for your help also how I do it.
lg
monchi
lg
monchi
AIDA64 does not support using multiple SensorPanels.  But you can use a single SensorPanel on any monitor you've got.
