Anyone have an idea as to why my 5" monitor will only work and display my sensor panel when it is plugged into a regular USB? Whenever I plug my monitor into a motherboard USB header, it doesnt get recognized and will not diplay the sensor panel. I've tried looking all over the internet for solutions and come up empty
Asrock H670M-ITX/AX LGA 1700 Intel H670 mb...i5 12400 cpu
Which USB screen you are using? Had you tried other USB device like USB mouse to connect to your MB USB header?
