spyder Posted October 17, 2022 Posted October 17, 2022 I'm wondering if there has been any updates on the scaling issue between a 4K main monitor with 150% scaling and a 7" 1024x600 2nd screen? I can get the downloaded sensor panel to display correctly on the main monitor by using compatibility mode from previous solutions but the panel is still obviously too big to fit correctly to the 2nd screen with 100% scaling. I would appreciate an answer even if it's just a simple "no." At least I can then return the 7" monitor I specifically bought for this purpose and get my money back. TIA. Quote
Solution Fiery Posted October 17, 2022 Solution Posted October 17, 2022 2 hours ago, spyder said: I'm wondering if there has been any updates on the scaling issue between a 4K main monitor with 150% scaling and a 7" 1024x600 2nd screen? I can get the downloaded sensor panel to display correctly on the main monitor by using compatibility mode from previous solutions but the panel is still obviously too big to fit correctly to the 2nd screen with 100% scaling. I would appreciate an answer even if it's just a simple "no." At least I can then return the 7" monitor I specifically bought for this purpose and get my money back. TIA. In the short run I cannot promise a quick & easy fix for that issue. We may be able to come up with a workaround, but most likely it can only happen next year. Quote
spyder Posted October 17, 2022 Author Posted October 17, 2022 Thank you for the reply. I hope a fix is possible and look forward to it next year. Quote
