CANE Posted November 8, 2022 Posted November 8, 2022 (edited) I've just upgraded from a RX580 to RX6600XT and Aida it is not showing up anymore GPU temp, GPU cooling fans, etc. What else to check/try? Thank you! forgot to mention, running Win10 Pro (OS Version 10.0.19045.2193) Edited November 8, 2022 by CANE update Quote
Fiery Posted November 9, 2022 Posted November 9, 2022 11 hours ago, CANE said: I've just upgraded from a RX580 to RX6600XT and Aida it is not showing up anymore GPU temp, GPU cooling fans, etc. What else to check/try? Thank you! forgot to mention, running Win10 Pro (OS Version 10.0.19045.2193) Make sure to have the latest AMD Adrenalin video drivers installed. Sometimes the installation messes up the AMD video driver API modules. In which case reinstalling the video drivers could help. 1 Quote
CANE Posted November 9, 2022 Author Posted November 9, 2022 Hi Fiery I had to removed the previous (updated) AMD Adrenaline and do a fresh install, again. It fixed the problem, thanks! Quote
