Wendi Posted November 29, 2022 Posted November 29, 2022 Since i installed an Hyper-V adapter (needed for V-machines, sandboxing, etc) sensorpanel shows <head> error in the "external IP" sensor and all other net sensors had to be reconfigured as NIC2 to read information. Is there any way so External IP can be readed from NIC2? there isn'tt any option for that. Thanks Quote
Solution Fiery Posted December 1, 2022 Solution Posted December 1, 2022 On 11/29/2022 at 4:39 PM, Wendi said: Since i installed an Hyper-V adapter (needed for V-machines, sandboxing, etc) sensorpanel shows <head> error in the "external IP" sensor and all other net sensors had to be reconfigured as NIC2 to read information. Is there any way so External IP can be readed from NIC2? there isn'tt any option for that. Thanks Is the issue still persists? We've adjusted that feature from our end and it should work again now. 1 Quote
Wendi Posted December 2, 2022 Author Posted December 2, 2022 20 hours ago, Fiery said: Is the issue still persists? We've adjusted that feature from our end and it should work again now. It is working perfectly now, thank you so much! Quote
