HelloHi Posted December 4, 2022 Posted December 4, 2022 Hi, new here. So I wanted to do a system stability test and I clicked on Stress GPU(s) and a dialog appeared "TdrDelay value configured too low". In one of the articles I found that the TdrDelay value is in HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers but I couldn't find TdrDelay and I don't know if I should add the key manually. https://imgur.com/a/Cfk5UGD-The Registry Image Intel i3 1005g1-CPU Quote
Fiery Posted December 4, 2022 Posted December 4, 2022 3 hours ago, HelloHi said: Hi, new here. So I wanted to do a system stability test and I clicked on Stress GPU(s) and a dialog appeared "TdrDelay value configured too low". In one of the articles I found that the TdrDelay value is in HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers but I couldn't find TdrDelay and I don't know if I should add the key manually. https://imgur.com/a/Cfk5UGD-The Registry Image Intel i3 1005g1-CPU Add the new value as DWORD (32-bit) value using the right-click menu. Name it TdrDelay and set it to 8 Quote
HelloHi Posted December 5, 2022 Author Posted December 5, 2022 Hello, thanks for the quick response. Thanks for the support Im now not getting the dialog box Quote
