Ucin Posted December 21, 2022 Posted December 21, 2022 Hi, title says basically everything, I swaped 6600XT for 7900XT and suddenly there is no GPU power sensors section in sensor panel no more. On top of that vram clock readings shows values up to 20000 MHz, 10 times more it should be. I'm on windows 10 64bit and 2 monitor setup. Main 4K OLED LG on HDMI cable and secondary 5inch LCD on usb-c connection. Both set to 60Hz. Quote
Fiery Posted December 22, 2022 Posted December 22, 2022 20 hours ago, Ucin said: Hi, title says basically everything, I swaped 6600XT for 7900XT and suddenly there is no GPU power sensors section in sensor panel no more. On top of that vram clock readings shows values up to 20000 MHz, 10 times more it should be. I'm on windows 10 64bit and 2 monitor setup. Main 4K OLED LG on HDMI cable and secondary 5inch LCD on usb-c connection. Both set to 60Hz. We'll fix both issues in the next AIDA64 beta update. 1 Quote
Ucin Posted December 22, 2022 Author Posted December 22, 2022 Thanks for reply, do you have ETA for new beta? Quote
Fiery Posted December 29, 2022 Posted December 29, 2022 On 12/22/2022 at 3:41 PM, Ucin said: Thanks for reply, do you have ETA for new beta? First half of January 2023 Quote
Solution Fiery Posted January 6, 2023 Solution Posted January 6, 2023 On 12/30/2022 at 11:47 PM, Ucin said: Awesome The above mentioned new AIDA64 beta update is now available for download at: https://www.aida64.com/downloads/latesta64xebeta Quote
Trayal Posted January 11, 2023 Posted January 11, 2023 One very minor gripe on the power sensor -- this appears to be read as an integer, but is being displayed as a FP value, so power consumption is always showing as xxx.00. It'd be nice if we could tweak the display to remove those trailing zeroes. Quote
