gigimxul Posted January 9, 2023 Posted January 9, 2023 Hello, Under Sensors it's not showing the 2nd chassis fan. Mobo is ASRock Z690M-ITX/ax. AIDA64 version: v6.85.6300 Suggestions? Thank you! Quote
al3cs86 Posted January 9, 2023 Posted January 9, 2023 I have same issue with Asrock Z790 Taichi, i have 4 missing fans:) Also other issues:) Maybe will be fixed in next update Quote
Fiery Posted January 9, 2023 Posted January 9, 2023 4 hours ago, gigimxul said: Hello, Under Sensors it's not showing the 2nd chassis fan. Mobo is ASRock Z690M-ITX/ax. AIDA64 version: v6.85.6300 Suggestions? Thank you! Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
gigimxul Posted January 12, 2023 Author Posted January 12, 2023 Thank you! Upgrading to Version: 6.85.6318 worked for me! Quote
