glabi Posted January 12, 2023 Posted January 12, 2023 Hi, I have a high flow next sensor and I can see the flow rate measured from that device in aida64. I'm not sure where the 2 decimal points are coming from though. In aquasuite and on the high flow next itself it has an accuracy of 1 decimal point. And ideally I want this flow to be rounded to the nearest integer. Is there a way to do that? I can't insert the image for some reason but here is a link to it. Quote
Fiery Posted August 23, 2025 Posted August 23, 2025 On 1/12/2023 at 3:40 PM, glabi said: Hi, I have a high flow next sensor and I can see the flow rate measured from that device in aida64. I'm not sure where the 2 decimal points are coming from though. In aquasuite and on the high flow next itself it has an accuracy of 1 decimal point. And ideally I want this flow to be rounded to the nearest integer. Is there a way to do that? I can't insert the image for some reason but here is a link to it. We've implemented the requested new option (Decimal digits for flow sensors) in the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta Quote
