mol Posted February 13, 2023 Posted February 13, 2023 Just got a new build with Asus TUF GAMING H770-PRO WIFI motherboard and Windows 11. I have two same cpu fans connected to CPU & CPU OPT headers, and two same case fans connected to CHA FAN 3 & CHA FAN 4 headers. AIDA64 v6.85.6300 doesn't show one case fan, and reports others with incorrect labels (see the picture below). Fans with 400+ RPMs are CPU fans. ISA sensor dump is attached: isasensordump.txt The same fans as reported by HWiNFO64 v7.36-4960: Quote
Fiery Posted February 13, 2023 Posted February 13, 2023 40 minutes ago, Dr.MoL said: Just got a new build with Asus TUF GAMING H770-PRO WIFI motherboard and Windows 11. I have two same cpu fans connected to CPU & CPU OPT headers, and two same case fans connected to CHA FAN 3 & CHA FAN 4 headers. AIDA64 v6.85.6300 doesn't show one case fan, and reports others with incorrect labels (see the picture below). Fans with 400+ RPMs are CPU fans. ISA sensor dump is attached: isasensordump.txt The same fans as reported by HWiNFO64 v7.36-4960: Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
mol Posted February 13, 2023 Author Posted February 13, 2023 1 hour ago, Fiery said: Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thank you for the reply. Result is better, but still is not correct: "Chassis #2" should be "CPU OPT", "Chassis #4" - "Chassis #3", "AIO Pump" - "Chassis #4". Sensors debug report: isasensordump.txt Quote
Fiery Posted February 13, 2023 Posted February 13, 2023 42 minutes ago, Dr.MoL said: Thank you for the reply. Result is better, but still is not correct: "Chassis #2" should be "CPU OPT", "Chassis #4" - "Chassis #3", "AIO Pump" - "Chassis #4". Sensors debug report: isasensordump.txt Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. 1 Quote
mol Posted February 13, 2023 Author Posted February 13, 2023 2 hours ago, Fiery said: Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Thanks Fiery, that helped! All my fans are now reported correctly: Thank you for fast fixing this issue! Quote
Fiery Posted February 13, 2023 Posted February 13, 2023 54 minutes ago, Dr.MoL said: Thanks Fiery, that helped! All my fans are now reported correctly: Thank you for fast fixing this issue! Thank you for your feedback 1 Quote
