Terminus Posted February 21, 2023 Posted February 21, 2023 I have already searched a lot and thought I had found something several times. But at the end of the day, there is no solution to my problem. Relevant configuration here: Current Windows 10 (perhaps necessary: on Asus Z790 Apex) and current AIDA64, 2 x D5 Next pump + High Flow Next. The problem: The water temperature sensor of the High Flow Next is not displayed in AIDA64 (is available in Aquasuite). However, the flow sensor of the High Flow Next can be selected. Only the sensors of the two pumps are available as water temperature sensors. A colleague in a forum has D5 Next + High Flow Next and both water temperature sensors are displayed there (perhaps AIDA64 does not display more than 2 temperature sensors?). What can I do? Maybe @Fiery can take care of this? Would be very grateful for any help Quote
Terminus Posted February 26, 2023 Author Posted February 26, 2023 It's really too bad, you're just ignored. Quote
Solution Fiery Posted March 1, 2023 Solution Posted March 1, 2023 On 2/21/2023 at 7:05 AM, Terminus said: I have already searched a lot and thought I had found something several times. But at the end of the day, there is no solution to my problem. Relevant configuration here: Current Windows 10 (perhaps necessary: on Asus Z790 Apex) and current AIDA64, 2 x D5 Next pump + High Flow Next. The problem: The water temperature sensor of the High Flow Next is not displayed in AIDA64 (is available in Aquasuite). However, the flow sensor of the High Flow Next can be selected. Only the sensors of the two pumps are available as water temperature sensors. A colleague in a forum has D5 Next + High Flow Next and both water temperature sensors are displayed there (perhaps AIDA64 does not display more than 2 temperature sensors?). What can I do? Maybe @Fiery can take care of this? Would be very grateful for any help Yes, you're correct in your assumption that AIDA64 only supports up to two water temperature sensors across all Aqua Computer devices. In the next AIDA64 beta update we'll increase it to four to make your setup work better. 1 Quote
Terminus Posted March 1, 2023 Author Posted March 1, 2023 Yes, great. thx for this positiv Information When will be the next beta-release? Quote
Fiery Posted March 1, 2023 Posted March 1, 2023 6 minutes ago, Terminus said: Yes, great. thx for this positiv Information When will be the next beta-release? Hopefully in 2 days 1 Quote
Fiery Posted March 3, 2023 Posted March 3, 2023 On 3/1/2023 at 1:05 PM, Terminus said: Yes, great. thx for this positiv Information When will be the next beta-release? It's available for download now: https://www.aida64.com/downloads/latesta64xebeta 1 Quote
Terminus Posted March 3, 2023 Author Posted March 3, 2023 Great, thank you very much. I'll try it out this evening. *Edit I will find the Build 6336, its the old one? *Edit 2 I was to fast Now its theBuidld 6341 Thanks Quote
