Hi, I install the new versión of Aida and now when I try to put the addon for logitech g15 screen keyboard the aida show an error: LCD connect failed. Where's the problem with the prevous version it works perfectly.
Thanks in advance!
What version of G15 drivers do you have installed? What sort of Windows operating system do you have installed? (Win7 64-bit maybe?)
Thanks, when you talk about the drivers I check that the g15 driver are outdated, I update it to the last version and now works.
Thanks!
