On 5/15/2023 at 5:03 PM, Simsense said:
I am also having this same issue with the ASRock B650E PG-ITX but with the 7900x.  Some notables missing were MB fans and CPU voltages.  I attached my copy of the sensor dump fwiw.
Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know how it works.
The fans and voltage values I checked appear to be accurate except for one: CPU SoC.  The value comes in at half of what I find in HWinfo, as if it's reading only one core of the entire chip.
Thanks for the quick update, it's very much appreciated.
Hi, i'm using the same CPU (different motherboard - ROG STRIX X670E-E GAMING WIFI) and it seems that my cpu usage is mostly 0% unless the load is heavy, but on idle it always says it's at 0%, while HWINFO says it's mostly around 3/4% on idle. Could it be that there are still some sensors wrong? Using the latest beta version.
Try to enable Windows 11 CPU utilization measurement workaround in AIDA64 / main menu / File / Preferences / Stability and check if it makes it work better.
