Marda89 Posted May 13, 2023 Posted May 13, 2023 Hello all, I have just installed a water cooling flow sensor. Unfortunately, only the internal temperature sensor is displayed in Aida, but not the flow. In the BIOS I can see it though, so it is properly connected. I have also already activated the embedded controller in the settings. Mainboard: ASUS ROG Crosshair X670E Hero Controller: Nuvoton NCT6799D Aida Version: 6.88.6413 Beta Does anyone else have an idea what the problem could be? Thank Quote
Marda89 Posted June 16, 2023 Author Posted June 16, 2023 I now have version 6.88.6426 beta, Problem remains. Quote
Marda89 Posted August 1, 2023 Author Posted August 1, 2023 Now on Version 6.90.6500, nothing changed. Good Support so far! Quote
Marda89 Posted September 3, 2023 Author Posted September 3, 2023 On Version 6.90.6517 Beta, Problem still remains 1 Quote
Tae Hoon No Posted September 5, 2023 Posted September 5, 2023 can you see flow meter in another software? (in BIOS setup, HWINFO, etc...) if there are no sensor value, your flow meter is just getting power on MB, not report flowrate. some of flow meter has only 2pin(PWR/GND). Quote
Marda89 Posted September 26, 2023 Author Posted September 26, 2023 On 9/5/2023 at 2:27 AM, Tae Hoon No said: can you see flow meter in another software? (in BIOS setup, HWINFO, etc...) if there are no sensor value, your flow meter is just getting power on MB, not report flowrate. some of flow meter has only 2pin(PWR/GND). Expand Thank you for your answer. In HWinfo I see the sensor / flow rate. I also see it in the bios. Im running the latest beta version, 6.92.6603. Quote
rinaldop Posted September 28, 2023 Posted September 28, 2023 I am fairly new to Aida64 so I cannot speak with 100% accuracy but I know that there are sensors that Aida64 cannot read that HWiNFO can. For example I have a new model Corsair cooler and I have not been able to get any info from it except the AIO fan speed. People here have been asking for Corsair cooler support for a long time but the Aida64 devs have said that data is difficult to read, yet HWiNFO can see all my fans. Your flow meter must not be supported yet, if ever. Quote
Marda89 Posted September 28, 2023 Author Posted September 28, 2023 On 9/28/2023 at 2:06 AM, rinaldop said: I am fairly new to Aida64 so I cannot speak with 100% accuracy but I know that there are sensors that Aida64 cannot read that HWiNFO can. For example I have a new model Corsair cooler and I have not been able to get any info from it except the AIO fan speed. People here have been asking for Corsair cooler support for a long time but the Aida64 devs have said that data is difficult to read, yet HWiNFO can see all my fans. Your flow meter must not be supported yet, if ever. Expand That's a bummer. What surprises me, Aida can read the Asus Embedded Controller (EC). I have also activated the readout, but apparently not all values canbe read. Should this really be the case, really a pathetic display for Aida. The sensor panel has great potential, this is also the reason why I use Aida and bought it, but what use is it if you can not see everything. I will probably not extend the license then. Quote
objecttothis Posted October 4, 2023 Posted October 4, 2023 I have an Asus ROG Crosshair VIII Hero X570 board and it appears that I have the same problem where it's not seeing all the values in the Asus Embedded Controller. HWiNFO sees Flow, T-Sensor, Water In and Water Out and reports values under the EC heading, but AIDA64 is only reporting T-sensor which I have connected to report the ambient temperature. Does anyone know the best place to report that AIDA64 is not properly reading the Asus Embedded Controller but other applications can? Quote
objecttothis Posted October 4, 2023 Posted October 4, 2023 When I enabled Embedded Controller (EC) Bank Switching in Preferences > Stability both the Water In and Water Out sensors appeared, but the flow sensor from the flow header on the motherboard is still missing. Quote
Marda89 Posted November 16, 2023 Author Posted November 16, 2023 Is there anything new on this? It still doesn't work for me with the latest version. Quote
