iensgoal Posted May 27, 2023 Posted May 27, 2023 Hi, suddenly when i opened my computer i noticed that the CPU temp monitor was displaying 90degs the number was stuck at 90deg doesn't change, i used 3rd party apps and it shows the normal 40deg wondering what's going on, haven't updated windows or changed anything i updated aida to the latest beta v6.88.6423(beta) and even then the temp is at 90deg attached my setup and sensor page DxDiag.txt Quote
Fiery Posted May 28, 2023 Posted May 28, 2023 21 hours ago, iensgoal said: Hi, suddenly when i opened my computer i noticed that the CPU temp monitor was displaying 90degs the number was stuck at 90deg doesn't change, i used 3rd party apps and it shows the normal 40deg wondering what's going on, haven't updated windows or changed anything i updated aida to the latest beta v6.88.6423(beta) and even then the temp is at 90deg attached my setup and sensor page DxDiag.txt 120.37 kB · 0 downloads Does it get back to normal value after restarting your computer? Quote
