benny_k Posted January 11, 2013 Posted January 11, 2013 Hi I use the AIDA64 to monitor my temps on CPU, MB, and my 2 GPUs (MSI HD 7970 Lightning). When I stress test them and compare the numbers to MSIs afterburner I found that the GPU1 was 10 degrees Celsius cooler in the AIDA64 than the MSI afterburner, but the GPU2 was close on target. Why is that? Best Regards Benny Quote
Fiery Posted January 12, 2013 Posted January 12, 2013 Maybe MSI Afterburner uses an offset of +10 Celsius on the GPU1 temperature reading. You can apply such offset on AIDA64 temperature readings in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction. Regards, Fiery Quote
