Switch0r Posted June 30, 2023 Posted June 30, 2023 The M.2 shows the wrongs temps. Samsung M.2 SDD has Kingston temps as you can see. Left is corect and right is wrong. Quote
Fiery Posted July 1, 2023 Posted July 1, 2023 14 hours ago, Switch0r said: The M.2 shows the wrongs temps. Samsung M.2 SDD has Kingston temps as you can see. Left is corect and right is wrong. You use incorrect custom labels for your drives. The temperatures are correct, but you need to rename "M.2 980 PRO 2TB" to "KINGSTON 2TB" and "M.2 980 PRO 2TB #2" to "KINGSTON 2TB #2". You of course need to do the same with the current "KINGSTON 2TB" labels too. Quote
