Jamie Johnson Posted July 6, 2023 Posted July 6, 2023 Hello, CPU, I assume package, temperature reading on this board are incorrect DIMM sensor readings are not present IPMI readings are correct, attached for reference. Open to assist validating fixes. Regards, Jamie Quote
Fiery Posted July 12, 2023 Posted July 12, 2023 On 7/6/2023 at 6:03 AM, Jamie Johnson said: Hello, CPU, I assume package, temperature reading on this board are incorrect DIMM sensor readings are not present IPMI readings are correct, attached for reference. Open to assist validating fixes. Regards, Jamie Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
Jamie Johnson Posted July 14, 2023 Author Posted July 14, 2023 Thank you for your response. I've attached ISA Sensor Dump as requested. Hope it finds you well. Regards, Jamie isasensordump.txt Quote
