CheeseSteak Posted July 20, 2023 Posted July 20, 2023 Just started to dabble with making a sensor panel. Downloaded and purchased AIDA64 extreme and noticed there are some missing voltage sensors. Is there a setting to "unhide" these sensors? AIDA64 version 6.90.6500 PC Specs: AMD-7900X. ASRock X670E Steel Legend. Attached are some pics of AIDA CPUID, the "sensors" page, as well as the available selections within the sensor panel manager. Any assistance is appreciated, thanks! Quote
Fiery Posted July 22, 2023 Posted July 22, 2023 On 7/20/2023 at 1:50 PM, CheeseSteak said: Just started to dabble with making a sensor panel. Downloaded and purchased AIDA64 extreme and noticed there are some missing voltage sensors. Is there a setting to "unhide" these sensors? AIDA64 version 6.90.6500 PC Specs: AMD-7900X. ASRock X670E Steel Legend. Attached are some pics of AIDA CPUID, the "sensors" page, as well as the available selections within the sensor panel manager. Any assistance is appreciated, thanks! Which voltage rails do you miss? Quote
CheeseSteak Posted July 25, 2023 Author Posted July 25, 2023 Missing the CPU Core (along with all the individual core voltages, core 0-12), DRAM, and the CPU VDDCR_VDD. I'm really only concerned with the CPU Core/individual core voltages. I have tried selecting the "Windows 11 CPU utilization measurement workaround" checkbox in the Stability tab, as well as the "Enable shared memory" checkbox in the External Applications tab. Quote
CheeseSteak Posted July 25, 2023 Author Posted July 25, 2023 I saw in a different post from another user, in a similar situation as mine that you asked for the ISA Sensor Dump. I've gone ahead and attached the .txt file. Not sure if you needed it but hope its helpful. isasensordump.txt Quote
citrus333 Posted September 22, 2023 Posted September 22, 2023 Asrock PG Riptide board here. Aida64 does not detect most voltage values, like Vcore and VDD. VDD on Aida is showing the VDD2_CPU voltage. Quote
