Good day,
I am getting a crash when running the benchmark CPU zlib. It seems all other tests are stable, including xtu stresses, OCCT tests, ycruncher tests and your own Aidata64 stability test for many hours. I did notice there was some post about this test specifically crashing pcs but they are a few years old now. Just wondering if there is anything still going on with this?
  On 7/27/2023 at 5:25 PM, Pro4x said:
Good day,
Expand
It definitely shouldn't crash on a stable system.  Can you check if it passes if you disable Turbo Boost?
