erixx11 Posted July 30, 2023 Posted July 30, 2023 Hello, Aida64 6.90.6500 B650E board (Asrock/NZXT N7) AMD Ryzen 7800X3D stock settings RAM: Corsair CMT32GX5M2B6000Z30 (2x16) Windows 11 Trying to find best RAM settings I'm running different settings and then Aida Memory Cache Benchmark. With any given RAM setting, if I immediately rerun Aida, I obtain huge discrepancies, like these READs 1st run: 61.600 2nd run: 66.000 3rd run: 74.000 I've also seen even crazier reruns, like: 1st run: 107.000 2nd run: 61.000 How to understand these? Can I do something to obtain consistent results to base on my final 24/7 settings? Thank you very much Quote
erixx11 Posted July 30, 2023 Author Posted July 30, 2023 just some further details: Three SOC voltage settings, 3 runs each one after the other (READ). 1. Auto SOC voltage (=1.21v) 61.600 - 66.000 - 74.000 2. 1.25 SOC voltage 65.500 - 82.300 - 67.500 3. 1.29 SOC voltage 69.700 - 64.000 - 103.000 Quote
Fiery Posted July 31, 2023 Posted July 31, 2023 On 7/30/2023 at 11:37 AM, erixx11 said: Hello, Aida64 6.90.6500 B650E board (Asrock/NZXT N7) AMD Ryzen 7800X3D stock settings RAM: Corsair CMT32GX5M2B6000Z30 (2x16) Windows 11 Trying to find best RAM settings I'm running different settings and then Aida Memory Cache Benchmark. With any given RAM setting, if I immediately rerun Aida, I obtain huge discrepancies, like these READs 1st run: 61.600 2nd run: 66.000 3rd run: 74.000 I've also seen even crazier reruns, like: 1st run: 107.000 2nd run: 61.000 How to understand these? Can I do something to obtain consistent results to base on my final 24/7 settings? Thank you very much Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
erixx11 Posted August 3, 2023 Author Posted August 3, 2023 On 7/31/2023 at 3:46 PM, Fiery said: Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Getting into this debugging thing Thanks ahead! ------[ Versions ]------ Program Version : AIDA64 Extreme v6.90.6500 BenchDLL Version: 4.6.876.8-x64 Windows Version : Microsoft Windows 11 Home 10.0.22621.2070 (64-bit) GetProductInfo : 0x00000065 ------[ CPU Info ]------ CPU Type : OctalCore AMD Ryzen 7 7800X3D, 4900 MHz (48.5 x 101) CPU Alias : Raphael CPU Platform : Socket AM5 CPU Stepping : RPL-B2 Instruction Set : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, AVX, AVX2, AVX-512, FMA, AES, SHA CPUID Manufacturer: AuthenticAMD CPUID CPU Name : AMD Ryzen 7 7800X3D 8-Core Processor CPUID Revision : 00A60F12h Platform ID : BEh (Socket AM5) HTT / CMP Units : 2 / 8 Max. NUMA Node : 0 Tjmax Temperature : 0 Celsius HTC Temperature Limit : 115 Celsius CPU Thermal Design Power: 120 W ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : NZXT N7 B650E Motherboard Chipset : AMD B650E, AMD K19.6 FCH, AMD K19.6 IMC DMI MB Manufacturer : NZXT DMI MB Product : N7 B650E DMI MB Version : Default string DMI MB Serial : Default string DMI SYS Manufacturer: NZXT DMI SYS Product : N7 B650E DMI SYS Version : Default string DMI SYS Serial : Default string DMI BIOS Version : 1.24 ------[ CPUID Registers / Logical CPU #0 ]------ allcpu: Package 0 / Core 0 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-00100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000000 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000000 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000000-00000100-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000000 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000000 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000000 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000000 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #1 ]------ allcpu: Package 0 / Core 0 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-01100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000001 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000001 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000001-00000100-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000001 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000001 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000001 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000001 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #2 ]------ allcpu: Package 0 / Core 1 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-02100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000002 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000002 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000002-00000101-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000002 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000002 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000002 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000002 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #3 ]------ allcpu: Package 0 / Core 1 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-03100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000003 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000003 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000003-00000101-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000003 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000003 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000003 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000003 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #4 ]------ allcpu: Package 0 / Core 2 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-04100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000004 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000004 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000004-00000102-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000004 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000004 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000004 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000004 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #5 ]------ allcpu: Package 0 / Core 2 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-05100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000005 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000005 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000005-00000102-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000005 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000005 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000005 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000005 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #6 ]------ allcpu: Package 0 / Core 3 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-06100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000006 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000006 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000006-00000103-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000006 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000006 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000006 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000006 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #7 ]------ allcpu: Package 0 / Core 3 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-07100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000007 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000007 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000007-00000103-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000007 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000007 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000007 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000007 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #8 ]------ allcpu: Package 0 / Core 4 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-08100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000008 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000008 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000008-00000104-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000008 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000008 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000008 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000008 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #9 ]------ allcpu: Package 0 / Core 4 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-09100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-00000009 [SL 00] CPUID 0000000B: 00000004-00000010-00000201-00000009 [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 00000009-00000104-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-00000009 [SL 00] CPUID 80000026: 00000004-00000010-00000201-00000009 [SL 01] CPUID 80000026: 00000004-00000010-00000302-00000009 [SL 02] CPUID 80000026: 00000004-00000010-00000403-00000009 [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #10 ]------ allcpu: Package 0 / Core 5 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-0A100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-0000000A [SL 00] CPUID 0000000B: 00000004-00000010-00000201-0000000A [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 0000000A-00000105-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-0000000A [SL 00] CPUID 80000026: 00000004-00000010-00000201-0000000A [SL 01] CPUID 80000026: 00000004-00000010-00000302-0000000A [SL 02] CPUID 80000026: 00000004-00000010-00000403-0000000A [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #11 ]------ allcpu: Package 0 / Core 5 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-0B100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-0000000B [SL 00] CPUID 0000000B: 00000004-00000010-00000201-0000000B [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 0000000B-00000105-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-0000000B [SL 00] CPUID 80000026: 00000004-00000010-00000201-0000000B [SL 01] CPUID 80000026: 00000004-00000010-00000302-0000000B [SL 02] CPUID 80000026: 00000004-00000010-00000403-0000000B [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #12 ]------ allcpu: Package 0 / Core 6 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-0C100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-0000000C [SL 00] CPUID 0000000B: 00000004-00000010-00000201-0000000C [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 0000000C-00000106-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-0000000C [SL 00] CPUID 80000026: 00000004-00000010-00000201-0000000C [SL 01] CPUID 80000026: 00000004-00000010-00000302-0000000C [SL 02] CPUID 80000026: 00000004-00000010-00000403-0000000C [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #13 ]------ allcpu: Package 0 / Core 6 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-0D100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-0000000D [SL 00] CPUID 0000000B: 00000004-00000010-00000201-0000000D [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 0000000D-00000106-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-0000000D [SL 00] CPUID 80000026: 00000004-00000010-00000201-0000000D [SL 01] CPUID 80000026: 00000004-00000010-00000302-0000000D [SL 02] CPUID 80000026: 00000004-00000010-00000403-0000000D [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #14 ]------ allcpu: Package 0 / Core 7 / Thread 0: Valid CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-0E100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-0000000E [SL 00] CPUID 0000000B: 00000004-00000010-00000201-0000000E [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 0000000E-00000107-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-0000000E [SL 00] CPUID 80000026: 00000004-00000010-00000201-0000000E [SL 01] CPUID 80000026: 00000004-00000010-00000302-0000000E [SL 02] CPUID 80000026: 00000004-00000010-00000403-0000000E [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ CPUID Registers / Logical CPU #15 ]------ allcpu: Package 0 / Core 7 / Thread 1: Valid, Virtual CPUID 00000000: 00000010-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 00000001: 00A60F12-0F100800-7EF8320B-178BFBFF CPUID 00000002: 00000000-00000000-00000000-00000000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000005: 00000040-00000040-00000003-00000011 CPUID 00000006: 00000004-00000000-00000001-00000000 CPUID 00000007: 00000001-F1BF97A9-00405FCE-10000010 [SL 00] CPUID 00000007: 00000020-00000000-00000000-00000000 [SL 01] CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000000-00000000-00000000-00000000 CPUID 0000000A: 00000000-00000000-00000000-00000000 CPUID 0000000B: 00000001-00000002-00000100-0000000F [SL 00] CPUID 0000000B: 00000004-00000010-00000201-0000000F [SL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 000002E7-00000980-00000988-00000000 [SL 00] [x87] CPUID 0000000D: 0000000F-00000990-00001800-00000000 [SL 01] [SSE] CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX] CPUID 0000000D: 00000040-00000340-00000000-00000000 [SL 05] [AVX-512 Opmask] CPUID 0000000D: 00000200-00000380-00000000-00000000 [SL 06] [AVX-512 Hi256] CPUID 0000000D: 00000400-00000580-00000000-00000000 [SL 07] [AVX-512 Hi16] CPUID 0000000D: 00000008-00000980-00000000-00000000 [SL 09] [PKRU] CPUID 0000000D: 00000010-00000000-00000001-00000000 [SL 0B] [CET_U] CPUID 0000000D: 00000018-00000000-00000001-00000000 [SL 0C] [CET_S] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-000000FF-00000000-00000002 [SL 00] CPUID 0000000F: 00000014-00000040-000000FF-00000007 [SL 01] CPUID 00000010: 00000000-00000002-00000000-00000000 [SL 00] CPUID 00000010: 0000000F-00000000-00000004-0000000F [SL 01] CPUID 80000000: 80000028-68747541-444D4163-69746E65 [AuthenticAMD] CPUID 80000001: 00A60F12-00000000-75C237FF-2FD3FBFF CPUID 80000002: 20444D41-657A7952-2037206E-30303837 [AMD Ryzen 7 7800] CPUID 80000003: 20443358-6F432D38-50206572-65636F72 [X3D 8-Core Proce] CPUID 80000004: 726F7373-20202020-20202020-00202020 [ssor ] CPUID 80000005: FF48FF40-FF48FF40-20080140-20080140 [L1D: 32 KB / L1I: 32 KB] CPUID 80000006: 5C002200-6C004200-04006140-03009140 [L2: 1024 KB] / L3: 98304 KB] CPUID 80000007: 00000000-0000003B-00000000-00006799 CPUID 80000008: 00003030-791EF257-0000400F-00010000 CPUID 80000009: 00000000-00000000-00000000-00000000 CPUID 8000000A: 00000001-00008000-00000000-1EBFBCFF CPUID 8000000B: 00000000-00000000-00000000-00000000 CPUID 8000000C: 00000000-00000000-00000000-00000000 CPUID 8000000D: 00000000-00000000-00000000-00000000 CPUID 8000000E: 00000000-00000000-00000000-00000000 CPUID 8000000F: 00000000-00000000-00000000-00000000 CPUID 80000010: 00000000-00000000-00000000-00000000 CPUID 80000011: 00000000-00000000-00000000-00000000 CPUID 80000012: 00000000-00000000-00000000-00000000 CPUID 80000013: 00000000-00000000-00000000-00000000 CPUID 80000014: 00000000-00000000-00000000-00000000 CPUID 80000015: 00000000-00000000-00000000-00000000 CPUID 80000016: 00000000-00000000-00000000-00000000 CPUID 80000017: 00000000-00000000-00000000-00000000 CPUID 80000018: 00000000-00000000-00000000-00000000 CPUID 80000019: F048F040-F0400000-00000000-00000000 CPUID 8000001A: 00000006-00000000-00000000-00000000 CPUID 8000001B: 00000BFF-00000000-00000000-00000000 CPUID 8000001C: 00000000-00000000-00000000-00000000 CPUID 8000001D: 00004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB] CPUID 8000001D: 00004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB] CPUID 8000001D: 00004143-01C0003F-000007FF-00000002 [SL 02] [L2U: 1 MB] CPUID 8000001D: 0003C163-03C0003F-00017FFF-00000001 [SL 03] [L3U: 96 MB] CPUID 8000001E: 0000000F-00000107-00000000-00000000 CPUID 8000001F: 00000001-000000B3-00000000-00000000 CPUID 80000020: 00000000-0000001E-00000000-00000000 [SL 00] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 01] CPUID 80000020: 0000000B-00000000-00000000-0000000F [SL 02] CPUID 80000020: 00000000-00000002-0000007F-00000000 [SL 03] CPUID 80000021: 00062FCF-0000015C-00000000-00000000 CPUID 80000022: 00000007-00084106-00000003-00000000 CPUID 80000023: 00000000-00000000-00000000-00000000 CPUID 80000024: 00000000-00000000-00000000-00000000 CPUID 80000025: 00000000-00000000-00000000-00000000 CPUID 80000026: 00000001-00000002-00000100-0000000F [SL 00] CPUID 80000026: 00000004-00000010-00000201-0000000F [SL 01] CPUID 80000026: 00000004-00000010-00000302-0000000F [SL 02] CPUID 80000026: 00000004-00000010-00000403-0000000F [SL 03] CPUID 80000027: 00000000-00000000-00000000-00000000 CPUID 80000028: 00000000-00000000-00000000-00000000 CPUID 8FFFFFFF: 00000000-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 1 MB, 8-way Associative, 64-byte Line L3 Unified Cache: 96 MB, 16-way Associative, 64-byte Line ------[ All CPUs ]------ CPU 0: APICID 0 / Package 0 / Core 0 / Thread 0: Valid CPU 1: APICID 1 / Package 0 / Core 0 / Thread 1: Valid, Virtual CPU 2: APICID 2 / Package 0 / Core 1 / Thread 0: Valid CPU 3: APICID 3 / Package 0 / Core 1 / Thread 1: Valid, Virtual CPU 4: APICID 4 / Package 0 / Core 2 / Thread 0: Valid CPU 5: APICID 5 / Package 0 / Core 2 / Thread 1: Valid, Virtual CPU 6: APICID 6 / Package 0 / Core 3 / Thread 0: Valid CPU 7: APICID 7 / Package 0 / Core 3 / Thread 1: Valid, Virtual CPU 8: APICID 8 / Package 0 / Core 4 / Thread 0: Valid CPU 9: APICID 9 / Package 0 / Core 4 / Thread 1: Valid, Virtual CPU 10: APICID 10 / Package 0 / Core 5 / Thread 0: Valid CPU 11: APICID 11 / Package 0 / Core 5 / Thread 1: Valid, Virtual CPU 12: APICID 12 / Package 0 / Core 6 / Thread 0: Valid CPU 13: APICID 13 / Package 0 / Core 6 / Thread 1: Valid, Virtual CPU 14: APICID 14 / Package 0 / Core 7 / Thread 0: Valid CPU 15: APICID 15 / Package 0 / Core 7 / Thread 1: Valid, Virtual ------[ MSR Registers / Logical CPU #0 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E8-F7E1-C970 [S200] MSR 000000E7: 0000-00E8-F8EA-E1BA [S200] MSR 000000E7: 0000-00E8-F983-F2E8 MSR 000000E8: 0000-00E9-A9FD-C900 [S200] MSR 000000E8: 0000-00E9-AA95-A51E [S200] MSR 000000E8: 0000-00E9-AB6F-C643 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-001F-48C2 [48.50x] [0.7688V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0028-08C2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DC-13A8 [S200] MSR C001029A: 0000-0000-04DC-3074 [S200] MSR C001029A: 0000-0000-04DC-3D67 MSR C001029B: 0000-0001-AB3E-710A [S200] MSR C001029B: 0000-0001-AB43-F16A [S200] MSR C001029B: 0000-0001-AB48-C097 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #1 ]------ CPU Clock (Normal): 4217 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 41.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-066C-F77E MSR 000000E8: 0000-00E9-B84D-50B0 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-88C2 [48.50x] [0.5375V] MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-0020-88C2 [48.50x] [0.7375V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-005E-08A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DC-7BF2 MSR C001029B: 0000-0001-AB57-43CF MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #2 ]------ CPU Clock (Normal): 4217 MHz CPU Clock (TSC): 4241 MHz CPU Multiplier: 41.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-0E87-35D2 MSR 000000E8: 0000-00E9-C111-BA52 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-006A-CACA [40.40x] [0.4813V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-001E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0028-C8C2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DC-A3A7 MSR C001029B: 0000-0001-AB65-F3E0 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #3 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-1661-7A1E MSR 000000E8: 0000-00E9-C9DE-55FE MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-001F-48C2 [48.50x] [0.7688V] MSR C0010293: 0000-0000-0068-08A7 [41.75x] [0.5500V] MSR C0010293: 0000-0000-0021-08C2 [48.50x] [0.7250V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-005E-08A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DC-D34C MSR C001029B: 0000-0001-AB74-794E MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #4 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-1E81-6634 MSR 000000E8: 0000-00E9-D2E9-5A57 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0068-0AC2 [38.80x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0068-C8A7 [41.75x] [0.5313V] MSR C0010293: 0000-0000-005F-48A7 [41.75x] [0.7688V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-005F-48A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DD-0564 MSR C001029B: 0000-0001-AB83-2B50 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #5 ]------ CPU Clock (Normal): 3919 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 38.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-26C7-ADC2 MSR 000000E8: 0000-00E9-DC28-EC2B MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0068-CAC2 [38.80x] [0.5313V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-001F-48C2 [48.50x] [0.7688V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-001F-48C2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DD-2ABD MSR C001029B: 0000-0001-AB91-47CD MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #6 ]------ CPU Clock (Normal): 4217 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 41.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-2EB7-C216 MSR 000000E8: 0000-00E9-E4E4-8E5A MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-001F-48C2 [48.50x] [0.7688V] MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0028-C8C2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DD-7CC0 MSR C001029B: 0000-0001-ABA0-3CCA MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #7 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-3698-1A30 MSR 000000E8: 0000-00E9-EDDA-244D MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-005E-08A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DD-BE85 MSR C001029B: 0000-0001-ABAF-0678 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #8 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-3ECA-CB2C MSR 000000E8: 0000-00E9-F6ED-1C48 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-0028-0AC2 [38.80x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0063-48A7 [41.75x] [0.6687V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0063-48A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DD-E730 MSR C001029B: 0000-0001-ABBD-8DA2 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #9 ]------ CPU Clock (Normal): 3919 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 38.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-48B2-B190 MSR 000000E8: 0000-00EA-01E9-7292 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-001E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0068-08A7 [41.75x] [0.5500V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0068-08A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DE-0A26 MSR C001029B: 0000-0001-ABCC-04EB MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #10 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-50C3-7B7A MSR 000000E8: 0000-00EA-0AE6-A431 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0068-C8A7 [41.75x] [0.5313V] MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-0066-88A7 [41.75x] [0.5875V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0066-88A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DE-327B MSR C001029B: 0000-0001-ABDA-7A4C MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #11 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-672F-A33C MSR 000000E8: 0000-00EA-23C4-3B7A MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0068-08A7 [41.75x] [0.5500V] MSR C0010293: 0000-0000-0060-0AC2 [38.80x] [0.7500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-005E-08A7 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DE-F84B MSR C001029B: 0000-0001-AC0A-0AD4 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #12 ]------ CPU Clock (Normal): 3919 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 38.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-705B-F5AE MSR 000000E8: 0000-00EA-2E09-3765 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-005F-48A7 [41.75x] [0.7688V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0068-CAC2 [38.80x] [0.5313V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0068-CAC2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DF-242F MSR C001029B: 0000-0001-AC18-5ADA MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #13 ]------ CPU Clock (Normal): 4217 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 41.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-7887-997C MSR 000000E8: 0000-00EA-371F-34A6 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-C8C2 [48.50x] [0.5313V] MSR C0010293: 0000-0000-0068-CAC2 [38.80x] [0.5313V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0028-08C2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DF-7B5A MSR C001029B: 0000-0001-AC27-5A83 MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #14 ]------ CPU Clock (Normal): 4898 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 48.5x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-80B6-5F64 MSR 000000E8: 0000-00EA-4089-EEB3 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-0028-48C2 [48.50x] [0.5437V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-0028-48C2 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04DF-F33D MSR C001029B: 0000-0001-AC37-4BAE MSR C0011023: 0102-0000-0000-0000 ------[ MSR Registers / Logical CPU #15 ]------ CPU Clock (Normal): 3919 MHz CPU Clock (TSC): 4242 MHz CPU Multiplier: 38.8x CPB PStates: 0 MSR 0000001B: 0000-0000-FEE0-0900 MSR 0000008B: 0000-0000-0A60-1203 MSR 000000E7: 0000-00E9-8C38-BA66 MSR 000000E8: 0000-00EA-4DD0-7CC1 MSR 0000010B: < FAILED > MSR C0010004: 0000-0000-0000-0000 MSR C0010005: 0000-0000-0000-0000 MSR C0010006: 0000-0000-0000-0000 MSR C0010007: 0000-0000-0000-0000 MSR C0010015: 0000-0001-C900-6011 MSR C001001F: 0000-0000-0000-0000 MSR C0010055: 0000-0000-0000-0000 MSR C0010058: 0000-0000-F000-001D MSR C0010061: 0000-0000-0000-0010 MSR C0010062: 0000-0000-0000-0000 MSR C0010063: 0000-0000-0000-0000 MSR C0010064: 8000-0000-4AB2-48A8 [42.00x] [0.2938 V] [ 4.20 A] [PState P0] MSR C0010065: 8000-0000-479E-4878 [94.00x] [0.7937 V] [ 3.00 A] [PState P1] MSR C0010066: 0000-0000-0000-0000 MSR C0010067: 0000-0000-0000-0000 MSR C0010068: 0000-0000-0000-0000 MSR C0010069: 0000-0000-0000-0000 MSR C001006A: 0000-0000-0000-0000 MSR C001006B: 0000-0000-0000-0000 MSR C0010070: < FAILED > MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-005E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-001E-08A7 [41.75x] [0.8000V] MSR C0010293: 0000-0000-0028-08C2 [48.50x] [0.5500V] MSR C0010293: 0000-0000-002B-88C8 [50.00x] [0.4625V] MSR C0010140: 0000-0000-0000-0005 MSR C0010141: 0000-0000-0000-0000 MSR C0010290: < FAILED > MSR C0010292: 0000-0001-0400-3789 MSR C0010293: 0000-0000-002B-88C8 MSR C0010294: 4F45-047F-0021-2192 MSR C0010296: 0000-0000-0048-4848 MSR C0010299: 0000-0000-000A-1000 MSR C001029A: 0000-0000-04E0-96DC MSR C001029B: 0000-0001-AC48-35C2 MSR C0011023: 0102-0000-0000-0000 PerformanceFrequency = 10000000 CPU Clock M.Method = 6 (APIC K10) PM Timer Address = 2056 (0808h) APIC Clock = 101.00 MHz (AT = 13233 / TT = 15008 / try = 1 / SKL = 25.25 MHz) APIC Clock = 101.00 MHz (AT = 13233 / TT = 15008 / try = 1 / SKL = 25.25 MHz) APIC Clock = 101.00 MHz (AT = 13233 / TT = 15008 / try = 1 / SKL = 25.25 MHz) APIC Clock = 101.00 MHz (AT = 13233 / TT = 15008 / try = 1 / SKL = 25.25 MHz) APIC Clock = 101.00 MHz (AT = 13233 / TT = 15008 / try = 1 / SKL = 25.25 MHz) CPU Clock = 4898.41 MHz / TSC Clock = 4241.97 MHz / CPU Mul = 48.50x CPU Clock = 4898.41 MHz / TSC Clock = 4242.06 MHz / CPU Mul = 48.50x CPU Clock = 3918.73 MHz / TSC Clock = 4242.01 MHz / CPU Mul = 38.80x CPU Clock = 4898.41 MHz / TSC Clock = 4242.00 MHz / CPU Mul = 48.50x CPU Clock = 4898.41 MHz / TSC Clock = 4241.96 MHz / CPU Mul = 48.50x CPU Clock Max = 4898.41 MHz / TSC Clock = 4241.95 MHz / CPU Mul = 48.50x CPU Clock Max = 4898.41 MHz / TSC Clock = 4241.95 MHz / CPU Mul = 48.50x CPU Clock Max = 4898.41 MHz / TSC Clock = 4242.01 MHz / CPU Mul = 48.50x CPU Clock Max = 4898.41 MHz / TSC Clock = 4242.00 MHz / CPU Mul = 48.50x CPU Clock Max = 4898.41 MHz / TSC Clock = 4242.01 MHz / CPU Mul = 48.50x Quote
Fiery Posted August 3, 2023 Posted August 3, 2023 26 minutes ago, erixx11 said: Getting into this debugging thing Thanks ahead! Thank you! It looks normal, and that's odd Can you please check if the huge fluctuations still present when you disable Turbo Boost? You can do that from AIDA64 too: right-click on the bottom Status Bar --> CPU Tweakings --> Disable Turbo Boost (you can find the button at roughly in the center of the window). Quote
erixx11 Posted August 3, 2023 Author Posted August 3, 2023 Dear @Fiery I'm afraid there's no turbo boost on my AMD Ryzen? And the option is absent from the CPU Tweakings panel. Quote
