DigitalFruit Posted February 19, 2013 Posted February 19, 2013 AIDA64 Extreme Edition version 2.80.2300 AIDA64 is not able to capture the following the following actual values CPU-NB VDD CPU-NB Voltage NB Voltage HT Voltage Here is the Embedded Controller Dump data ------[ AIDA64 v2.80.2300 ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601.18044 Service Pack 1 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-0100-000001-00101111-081210-ATHLON64$A7612200_A7612NMS V1.4 081210Motherboard Model : MSI NF980-G65 (MS-7612)Motherboard Chipset : nVIDIA nForce 980a SLI, AMD K10 DMI MB Manufacturer : MSIDMI MB Product : NF980-G65 (MS-7612)DMI MB Version : 1.0DMI MB Serial : To be filled by O.E.M.DMI SYS Manufacturer: MSIDMI SYS Product : MS-7612DMI SYS Version : 1.0DMI SYS Serial : To Be Filled By O.E.M.DMI BIOS Version : V1.4 ------[ Embedded Controller at 0066/0062 via Port I/O / Bank #0 ]------ 0000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ Time #1 = 0Time #2 = 0 Quote
Fiery Posted February 19, 2013 Posted February 19, 2013 1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 2) Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic. 3) Do you have a software that can show those values under Windows? Like MSI Core Center or MSI Control Center? 4) Can you see the mentioned voltage values on the H/W Monitor page of the BIOS Setup? Thanks, Fiery Quote
DigitalFruit Posted February 20, 2013 Author Posted February 20, 2013 ------[ AIDA64 v2.80.2300 ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601.18044 Service Pack 1 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-0100-000001-00101111-081210-ATHLON64$A7612200_A7612NMS V1.4 081210Motherboard Model : MSI NF980-G65 (MS-7612)Motherboard Chipset : nVIDIA nForce 980a SLI, AMD K10 DMI MB Manufacturer : MSIDMI MB Product : NF980-G65 (MS-7612)DMI MB Version : 1.0DMI MB Serial : To be filled by O.E.M.DMI SYS Manufacturer: MSIDMI SYS Product : MS-7612DMI SYS Version : 1.0DMI SYS Serial : To Be Filled By O.E.M.DMI BIOS Version : V1.4 ITE 87xx Port = 00hITE 87xx HWMonitor Port = 0000hITE 87xx Device ID = 0000hITE 87xx Version = 00h Winbond SuperIO Port = 00hWinbond SuperIO HWMonitor Port = 0000hWinbond SuperIO Device ID = 0723h Fintek SuperIO Port = 4EhFintek SuperIO HWMonitor Port = 0A00hFintek SuperIO Device ID = 0723h LPC47 SuperIO HWMonitor Port = 0000hLPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0A00 ]------ 0000 FF C3 00 00 01 FF FF FF FF FF 01 00 55 4C 00 300010 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF0020 D3 C2 6D 8B 62 64 4A D3 C7 FF FF FF FF FF FF FF0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF0050 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF0060 00 00 00 00 FF FF 00 78 00 00 FF 0A 40 24 FF 000070 FF FF 28 FF 59 FF 20 FF FF FF 00 00 00 29 00 000080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF A8 FF0090 00 00 00 00 14 FF 3F FF 42 04 FF 2A 55 05 FF 0A00A0 04 13 00 FF 02 01 3C 32 28 1E FF E5 CE B7 A0 0D00B0 03 49 00 FF 02 C7 3C 32 28 1E FF D9 B2 99 80 0E00C0 01 B7 00 FF 00 E7 3C 32 28 1E FF D9 B2 99 80 0F00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF00E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 0000F0 00 00 00 00 00 00 37 FF 02 88 FF 00 FF FF FF FF 0070 0072 0074 0076 0078 0079 007A 007B 007C 007D 007E 007FT: 255 40 88 32 255 255 0 0 0 41 0 0T: 255 40 88 32 255 255 0 0 0 39 0 0T: 255 39 89 32 255 255 0 0 0 37 0 0T: 255 39 89 32 255 255 0 0 0 37 0 0T: 255 38 88 32 255 255 0 0 0 37 0 0T: 255 39 88 32 255 255 0 0 0 39 0 0T: 255 39 88 32 255 255 0 0 0 38 0 0T: 255 39 89 32 255 255 0 0 0 38 0 0T: 255 38 89 32 255 255 0 0 0 40 0 0T: 255 39 89 32 255 255 0 0 0 39 0 0 Reg$20 CPU Core: r = 211, r*0.016 = 3.38Reg$21 CPU Aux: r = 194, r*0.016 = 3.10Reg$22 +3.3 V: r = 109, r*0.016 = 1.74Reg$23 +5 V: r = 139, r*0.016 = 2.22Reg$24 +12 V: r = 98, r*0.016 = 1.57Reg$25 -12 V: r = 100, r*0.016 = 1.60Reg$26 -5 V: r = 74, r*0.016 = 1.18 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP :_TZ_.THM1._TMP :_TZ_.THR0._TMP :_TZ_.THR1._TMP :_TZ_.TZ00._TMP :_TZ_.TZ01._TMP :_TZ_.RTMP :_TZ_.RFAN :_TZ_.RFAN(0) :_TZ_.RFAN(1) :_SB_.ATKD._HID :_SB_.ATKD.TMPR :_SB_.PCI0.LPC0.EC0_.CCTV :_SB_.PCI0.LPC0.EC0_.LRPM :_SB_.PCI0.LPC0.EC0_.HRPM :_SB_.PCI0.SBRG.EC0_.ECPU :_SB_.PCI0.SBRG.EC0_.TACH(0):_SB_.PCI0.SBRG.EC0_.TACH(1):_SB_.PCI0.SBRG.EC0_.TAH0 :_SB_.PCI0.SBRG.EC0_.TAH1 :_SB_.PCI0.SBRG.EC0_.ST00 :_SB_.PCI0.SBRG.EC0_.SC01 :_SB_.PCI0.SBRG.EC0_.SC02 :_SB_.PCI0.SBRG.EC0_.SC03 :_SB_.PCI0.SBRG.EC0_.SC04 :_SB_.PCI0.SBRG.EC0_.SC05 :_SB_.PCI0.SBRG.EC0_.SC06 :_SB_.PCI0.PIB_.EC0_.TCRT :_SB_.PCI0.SBRG.EC0_.CTPM :_SB_.PCI0.SBRG.EC__.CPUT :_SB_.PCI0.SBRG.EC__.SYST :_SB_.PCI0.LPC_.EC0_.CTMP :_SB_.PCI0.LPCB.EC0_.CTMP :_SB_.PCI0.LPC_.EC0_.TMP1 :_SB_.PCI0.LPC_.EC0_.TMP2 :_SB_.PCI0.LPC_.EC0_.TMPI :_SB_.PCI0.LPC_.EC0_.TMPV :_SB_.PCI0.LPCB.EC0_.A1TP :_SB_.PCI0.LPCB.EC0_.A2TP :_SB_.PCI0.LPCB.EC0_.FAN0 :_SB_.PCI0.LPCB.EC__.TS1R :_SB_.PCI0.LPCB.EC__.TS2R :_SB_.PCI0.LPCB.EC__.TS3R :_SB_.PCI0.LPCB.EC__.F1FL :_SB_.PCI0.LPCB.EC__.F1FH :_SB_.PCI0.LPCB.EC__.F2FL :_SB_.PCI0.LPCB.EC__.F2FH :_SB_.PCI0.LPC_.H8EC.RTMP :_SB_.PCI0.LPC_.H8EC.LTMP :_SB_.PCI0.LPC_.H8EC.MTMP :_SB_.PCI0.LPC_.H8EC.GTMP :_SB_.PCI0.LPCB.H8EC.CTMP :_SB_.PCI0.LPCB.H8EC.DTMP :_SB_.PCI0.LPCB.H8EC.GTMP :_SB_.PCI0.LPCB.H8EC.ITMP :_SB_.PCI0.LPCB.H8EC.MTMP :_SB_.PCI0.LPCB.H8EC.STMP :_SB_.PCI0.LPCB.H8EC.PFAN : ------[ nVIDIA THERM Fan ]------ Initial : 00 (0 ms)Step 5 : 00 (16 ms)Step 5 : 00 (31 ms)Step 5 : 00 (47 ms)Step 5 : 00 (62 ms)Step 5 : 00 (78 ms)Step 5 : 00 (94 ms)Step 5 : 00 (109 ms)Step 5 : 00 (125 ms)Step 5 : 00 (141 ms)Step 5 : 00 (156 ms)Step 10 : 00 (172 ms)Step 10 : 00 (187 ms)Step 10 : 00 (203 ms)Step 10 : 00 (219 ms)Step 10 : 00 (234 ms)Step 10 : 00 (250 ms)Step 10 : 00 (266 ms)Step 10 : 00 (281 ms)Step 10 : 00 (297 ms)Step 10 : 00 (312 ms)Step 50 : 00 (375 ms)Step 50 : 00 (437 ms)Step 50 : 00 (500 ms)Step 50 : 00 (562 ms)Step 50 : 00 (625 ms)Step 50 : 00 (687 ms)Step 50 : 00 (750 ms)Step 50 : 00 (812 ms)Step 50 : 00 (875 ms)Step 50 : 00 (937 ms)Step 100: 00 (1047 ms)Step 100: 00 (1156 ms)Step 100: 00 (1266 ms)Step 100: 00 (1375 ms)Step 100: 00 (1484 ms)Step 100: 00 (1594 ms)Step 100: 00 (1703 ms)Step 100: 00 (1812 ms)Step 100: 00 (1922 ms)Step 100: 00 (2031 ms)Step 200: 00 (2234 ms)Step 200: 00 (2437 ms)Step 200: 00 (2641 ms)Step 200: 00 (2844 ms)Step 200: 00 (3047 ms)Step 200: 00 (3250 ms)Step 200: 00 (3453 ms)Step 200: 00 (3656 ms)Step 200: 00 (3859 ms)Step 200: 00 (4062 ms) ------[ AIDA64 v2.80.2300 ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601.18044 Service Pack 1 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-0100-000001-00101111-081210-ATHLON64$A7612200_A7612NMS V1.4 081210Motherboard Model : MSI NF980-G65 (MS-7612)Motherboard Chipset : nVIDIA nForce 980a SLI, AMD K10 DMI MB Manufacturer : MSIDMI MB Product : NF980-G65 (MS-7612)DMI MB Version : 1.0DMI MB Serial : To be filled by O.E.M.DMI SYS Manufacturer: MSIDMI SYS Product : MS-7612DMI SYS Version : 1.0DMI SYS Serial : To Be Filled By O.E.M.DMI BIOS Version : V1.4 ------[ GPIO @ isa 24C0 ]------ 0000 08 48 48 65 60 60 60 08 08 08 08 08 08 08 08 080010 08 08 48 08 08 08 08 08 28 28 28 28 28 08 08 600020 08 08 08 08 28 68 68 68 68 08 68 08 08 08 08 480030 48 08 08 60 60 60 08 08 08 08 40 08 08 60 08 08 ------[ 2 SMBuses detected ]------ ------[ SMBus #0 ]------ SMBus Type : nForce2/3/4/5/6 - PrimarySMBus Port : 2D00Can Have SPD: YesScan Type : Full ------[ SMBus Device B00-D50 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 23 00 00 00 00 5B 11 .........#....[. 0080 43 4D 47 34 47 58 33 4D 32 42 31 36 30 30 43 37 CMG4GX3M2B1600C7 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D51 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 23 00 00 00 00 5B 11 .........#....[. 0080 43 4D 47 34 47 58 33 4D 32 42 31 36 30 30 43 37 CMG4GX3M2B1600C7 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D52 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 23 00 00 00 00 5B 11 .........#....[. 0080 43 4D 47 34 47 58 33 4D 32 42 31 36 30 30 43 37 CMG4GX3M2B1600C7 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D53 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 23 00 00 00 00 5B 11 .........#....[. 0080 43 4D 47 34 47 58 33 4D 32 42 31 36 30 30 43 37 CMG4GX3M2B1600C7 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus #1 ]------ SMBus Type : nForce2/3/4/5/6 - SecondarySMBus Port : 2E00Can Have SPD: NoScan Type : Full ------[ SMBus Device B01-D18 ]------ 0000 F8 00 00 F8 00 FF 00 00 00 18 FF FF FF FF FF FF ................ 0010 3F 28 00 17 00 17 00 00 FF FF FF FF FF FF FF FF ?(.............. 0020 95 92 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B01-D18 ]------ 0000 FFF8 FF00 FF00 FFF8 FF00 FFFF FF00 FF00 FF00 FF18 FFFF FFFF FFFF FFFF FFFF FFFF 0010 FF3F FF28 FF00 FF17 FF00 FF17 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FF95 FF92 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B01-D28 ]------ 0000 17 19 05 0A 01 80 0A FF FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 19 05 0A 01 80 0A FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 19 05 0A 01 80 0A FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 19 05 0A 01 80 0A FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B01-D28 ]------ 0000 1917 0519 0A05 FF0A FF01 FF80 FF0A FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 19FF 0519 0A05 FF0A FF01 FF80 FF0A FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 19FF 0519 0A05 FF0A FF01 FF80 FF0A FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 19FF 0519 0A05 FF0A FF01 FF80 FF0A FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B01-D30 ]------ 0000 87 45 21 00 00 21 00 00 FF FF FF FF FF FF FF FF .E!..!.......... 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 45 21 00 00 21 00 00 FF FF FF FF FF FF FF FF .E!..!.......... 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 45 21 00 00 21 00 00 FF FF FF FF FF FF FF FF .E!..!.......... 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 45 21 00 00 21 00 00 FF FF FF FF FF FF FF FF .E!..!.......... 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B01-D30 ]------ 0000 4587 2145 0021 0000 FF00 FF21 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 45FF 2145 0021 0000 FF00 FF21 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 45FF 2145 0021 0000 FF00 FF21 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 45FF 2145 0021 0000 FF00 FF21 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B01-D50 ]------ 0000 24 48 44 43 50 24 C2 00 58 02 03 02 4E 56 10 4C $HDCP$..X...NV.L 0010 03 02 48 02 82 37 04 80 EA 05 74 96 6F C9 02 E9 ..H..7....t.o... 0020 09 62 0B 35 8B 41 2C 11 3F CA 83 2A 3B 61 E5 67 .b.5.A,.?..*;a.g 0030 D8 38 27 4E 02 D1 5F C1 D4 B9 16 FC 18 87 47 14 .8'N.._.......G. 0040 B2 C0 FD A9 83 8B 7F 0D F2 21 32 CA FE 07 9E 6C ........!2....l 0050 E8 B7 7B 67 F3 06 E2 99 A9 D2 A0 4E 1F 8D B6 09 ..{g.......N.... 0060 F1 BA 14 20 8A 42 E4 AE 4A B9 87 AC C5 28 0A 87 ... .B..J....(.. 0070 62 56 05 1E F9 76 FA A4 D7 C8 8A 01 0F 17 CB D2 bV...v.......... 0080 A1 E0 C9 99 C3 CB CA D1 14 67 3B 37 C3 E2 F4 07 .........g;7.... 0090 DC 8F 4C C8 34 B9 F3 66 6D 0D A3 B3 99 31 03 75 ..L.4..fm....1.u 00A0 B5 CD 3C 4A F8 84 C4 87 B0 29 1B 1E 92 B3 CA EB ..<J.....)...... 00B0 27 D7 54 51 2B 4D 2D 56 CA 8A 16 CA E8 04 3D E1 '.TQ+M-V......=. 00C0 F8 51 12 35 0D 31 60 23 B2 A2 C8 BA BA 75 08 DF .Q.5.1`#.....u.. 00D0 23 3F C4 EA C4 E3 5B D9 64 9B 66 09 06 1E 14 BE #?....[.d.f..... 00E0 7C 7F EA AE 29 EC 9F 3B 0A EE 68 72 47 4A 60 98 |..)..;..hrGJ`. 00F0 5A 0A 82 CB E9 75 3C C1 C4 EB 08 18 EE 65 81 B9 Z....u<......e.. ------[ SMBus Device B01-D51 ]------ 0000 3C 53 F6 86 5B 63 F2 11 85 01 4B 2A 8A BD 38 A5 <S..[c....K*..8. 0010 60 64 62 F5 D0 8C 05 F9 EE C1 8E C4 0D 22 8A D7 `db..........".. 0020 F8 FC 7F C6 6C 1C 46 39 60 D0 DA B7 27 9C B9 69 ...l.F9`...'..i 0030 98 5C 08 67 9B 29 95 B3 C8 38 8D 87 EB 5C 8B F3 .\.g.)...8...\.. 0040 CA D9 89 63 8D F0 05 02 BF A6 A3 C7 9C 11 BA EE ...c............ 0050 FE 71 5B 87 50 94 6A 9A 01 2D 2E 92 39 E5 3D 0F .q[.P.j..-..9.=. 0060 F0 3B 1F 2B D9 97 F8 02 99 92 11 9F 8C B3 D7 DC .;.+............ 0070 11 EC B2 0C 48 8B D3 1D 5F 53 A1 64 61 31 79 3F ....H..._S.da1y? 0080 DB BB 87 8B 2E 14 04 C5 F2 40 51 2D 50 48 5A 21 .........@Q-PHZ! 0090 33 BF 88 94 C4 E4 54 33 68 D8 D0 3F 00 DE 76 41 3.....T3h..?..vA 00A0 68 73 CA 45 C7 6C 3F FB D5 D2 B0 5B AE E7 5B 06 hs.E.l?....[..[. 00B0 01 F9 E6 16 A4 3D 6F 71 3F 17 D5 27 83 85 CF E2 .....=oq?..'.... 00C0 0B 99 F4 EB 5C 4B EB CD 3F 62 6E A4 DE 10 28 13 ....\K..?bn...(. 00D0 ED 0D 3B A7 24 D8 83 04 C0 80 30 38 C7 6B 52 9F ..;.$.....08.kR. 00E0 23 18 3C EB 89 B3 95 E2 84 23 5F DC DD 82 32 1A #.<......#_...2. 00F0 27 4D A9 64 0D A4 21 2D CE 77 07 CA 1F E2 59 8D 'M.d..!-.w....Y. ------[ SMBus Device B01-D52 ]------ 0000 57 32 9C BA 38 BD 1D 09 DA 2F B2 7B 70 7E A1 3D W2..8..../.{p~.= 0010 A5 F8 8F 72 78 02 21 87 C0 29 79 78 0A 89 0B F4 ...rx.!..)yx.... 0020 27 90 29 51 08 91 62 4A 78 5E 8E 57 A0 86 21 7F '.)Q..bJx^.W..! 0030 76 78 9A 10 15 A2 B8 FA FC 84 E8 FF 40 74 47 DF vx..........@tG. 0040 98 34 BC 1C 82 C2 76 F2 30 B3 64 BF 78 D3 EC 85 .4....v.0.d.x... 0050 0E A9 E7 30 8B 00 00 00 5B 01 69 13 01 00 00 00 ...0....[.i..... 0060 7A D5 F7 C5 0C 00 40 2B B0 17 3E 6C D3 FF E4 71 z.....@+..>l...q 0070 06 16 CE CC 4E 6B 08 A0 FE 77 AA 16 A9 11 1B EA ....Nk...w...... 0080 12 5E 7D 9C 6F 41 74 ED 4A 3D AB 48 5F E1 6F 4E .^}.oAt.J=.H_.oN 0090 FD 68 07 67 AF 99 E4 F7 97 28 06 C5 4F 1A BB D6 .h.g.....(..O... 00A0 99 22 6A 3B 51 F7 83 EB FA ED C1 3A E0 9C FE FE ."j;Q......:.... 00B0 D3 8C 01 E9 DB 0E C9 E6 4E C1 E0 3A A5 18 6F 73 ........N..:..os 00C0 88 29 F1 FD DB 5A 17 3D DD E6 15 6A 79 B0 2E 4B .)...Z.=...jy..K 00D0 70 3C D7 C8 35 54 CD EF 7F 0D 73 D2 BE B4 D2 25 p<..5T...s....% 00E0 1D FC 22 A4 5D 91 68 65 9C E9 67 3D 8C 92 6D 46 ..".].he..g=..mF 00F0 91 FF B1 65 66 6D 5B E4 C9 9D A0 6B EC 9D D2 5A ...efm[....k...Z ------[ SMBus Device B01-D53 ]------ 0000 EA 43 6F E1 83 37 13 E3 22 95 CC 08 11 6C 45 2E .Co..7.."....lE. 0010 1D B9 8F EF 37 30 75 66 3B D7 D4 53 7C 34 10 51 ....70uf;..S|4.Q 0020 FA C4 9E 22 26 B2 E0 30 17 3B 21 80 8E 54 D8 85 ..."&..0.;!..T.. 0030 42 AF 77 84 13 3E 73 57 F2 FA 27 82 F3 61 E8 21 B.w..>sW..'..a.! 0040 34 B6 1C 5A 5A C6 1C 13 17 DF EA 85 0F 72 E5 BA 4..ZZ........r.. 0050 D8 1F 9F 54 24 71 C3 AA B3 91 90 50 CE 27 39 56 ...T$q.....P.'9V 0060 54 89 BE 45 0C 78 D2 85 07 C9 71 B7 A1 53 35 1A T..E.x....q..S5. 0070 60 1B B7 47 C0 E1 0B 7F AF BC 66 36 DA DB 09 A0 `..G.....f6.... 0080 F2 91 03 C6 96 84 7E D0 CB 1E 0C 72 8B CC AB 7E ......~....r...~ 0090 66 A6 86 59 84 B7 86 20 0E 1B 42 90 E4 6D 24 C4 f..Y... ..B..m$. 00A0 19 87 46 CB 78 74 C1 6C F0 3C 9C 1D D1 8A D9 CF ..F.xt.l.<...... 00B0 01 21 82 0C 68 86 8E DC 48 24 DF 7A FA 96 D2 04 .!..h...H$.z.... 00C0 7D 53 F9 D1 4F AB 4D 73 3D CE 1F F5 DA 24 F2 F9 }S..O.Ms=....$.. 00D0 DB B3 A6 A9 35 62 14 6F 3B 03 70 F4 CF AA 31 95 ....5b.o;.p...1. 00E0 FA 56 BC A6 35 6C 3D AA DE 94 0E 2D 5E 09 56 07 .V..5l=....-^.V. 00F0 03 C8 74 13 8F F2 E2 51 50 4A 6F 7F 26 08 82 2A ..t....QPJo&..* ------[ SMBus Device B01-D54 ]------ 0000 53 80 A8 59 5F 87 1A EF 74 0E CC 7F 5B 24 33 D1 S..Y_...t..[$3. 0010 AD 48 F4 11 23 BB 98 C7 1B 82 FD 30 0B 34 D6 C1 .H..#......0.4.. 0020 5A 70 CF 38 27 55 1F DC 16 C0 60 49 46 F8 6D 80 Zp.8'U....`IF.m. 0030 FD 41 8B CD 18 D3 D0 71 FF B5 7B 0D 7B 70 36 DB .A.....q..{.{p6. 0040 E4 7E 22 D0 1C 30 F2 D0 E1 E2 D5 D0 0D 1F 12 56 .~"..0.........V 0050 00 2F 6C FA AE 21 FA 0E B8 99 83 C5 52 58 3C DD ./l..!......RX<. 0060 7A B4 C9 6C 7A 10 68 69 0A 4A ED 3E 36 1E 84 DD z..lz.hi.J.>6... 0070 2B 6F CF 73 09 50 36 A9 F5 53 61 0C 47 92 70 A8 +o.s.P6..Sa.G.p. 0080 AA 15 FB A9 EE E2 9C 14 D3 5A 02 74 27 31 DC 2E .........Z.t'1.. 0090 49 DC 6A 9B 63 BB 75 07 62 ED 27 59 40 76 21 8A I.j.c.u.b.'Y@v!. 00A0 43 4D 6A 25 58 CC 6D 2F 7E E3 5D 86 21 4C E2 2F CMj%X.m/~.].!L./ 00B0 0B B2 59 24 EE 26 5C 30 57 67 7B 05 E4 56 98 E9 ..Y$.&\0Wg{..V.. 00C0 E6 2A 42 35 E6 6D DA 6D 4B EA F0 17 9B B0 51 3E .*B5.m.mK.....Q> 00D0 1D F0 35 DA ED 4D 4A 33 5F A2 0E C7 49 B8 23 6B ..5..MJ3_...I.#k 00E0 D4 DC D3 3E 30 3D B4 2A 29 6D 3A 59 C9 59 A3 35 ...>0=.*)m:Y.Y.5 00F0 5E B1 B2 D2 B8 7E 21 C9 0B C8 C5 18 B5 A3 7E 75 ^....~!.......~u ------[ SMBus Device B01-D55 ]------ 0000 07 F1 0F 99 3B 04 41 0E D8 AD 06 B0 62 17 D8 8C ....;.A.....b... 0010 BE AA 48 D4 40 97 62 CC 89 2E F4 35 DC C4 1E 30 ..H.@.b....5...0 0020 6B 51 E3 F5 A9 6D C2 C4 84 6C EA DB 52 4B A6 54 kQ...m...l..RK.T 0030 25 61 9C D3 BD 57 52 34 D0 10 E0 1C 40 0F 1A 12 %a...WR4....@... 0040 28 55 62 ED 49 FE B8 BB 7B C7 79 A3 27 21 D9 C1 (Ub.I...{.y.'!.. 0050 12 FD EA 3B 18 36 01 E0 91 1A A0 49 0F BA 86 94 ...;.6.....I.... 0060 D5 30 6E 2A 9B B5 D5 A9 94 D5 0A B8 1A 2A 3C 56 .0n*.........*<V 0070 1C 86 DA 7B D0 F7 2F 99 5A C3 0D F8 71 DD 6C DF ...{../.Z...q.l. 0080 3C 8E 45 6B 96 3C 17 83 71 2C 13 09 A3 D9 C3 03 <.Ek.<..q,...... 0090 34 C2 5A 99 8B 12 77 A8 6E 8E BC 07 2E A3 F0 C9 4.Z...w.n....... 00A0 15 F2 76 8C 53 FD 7A 02 4E A6 F2 C8 57 DF 5F 57 ..v.S.z.N...W._W 00B0 C5 D8 03 C6 4E F3 2F 81 90 C7 1E E7 82 03 48 CE ....N./.......H. 00C0 A0 FF DC 0E A0 DB 9E 01 08 22 81 28 E0 7A B9 37 .........".(.z.7 00D0 29 06 FB 67 71 9E 45 9F 00 8C C9 46 71 ED 77 C8 )..gq.E....Fq.w. 00E0 56 4F CA BF CA D8 9D 4B DA BE 3C BB 46 CF 66 4F VO.....K..<.F.fO 00F0 5E 56 20 B7 2D AB 96 AA 91 3E 67 16 F0 D8 A0 56 ^V .-....>g....V ------[ SMBus Device B01-D56 ]------ 0000 5D CB 75 DA 23 90 0B C4 FD F4 B6 2D A4 AD 82 64 ].u.#......-...d 0010 D6 6A 6E 80 41 62 C9 0F 2C C8 3A 13 19 8C F2 6D .jn.Ab..,.:....m 0020 3B 82 45 27 05 CF 71 2D A6 DC 85 C5 BB 23 0D C8 ;.E'..q-.....#.. 0030 D6 42 ED 9D 56 80 60 65 00 55 56 44 4E 4E 11 A8 .B..V.`e.UVDNN.. 0040 D1 5B AA 46 7D EE AC 6B C1 65 61 73 2E A1 48 B7 .[.F}..k.eas..H. 0050 45 C1 87 16 D7 84 1F A3 8E 34 1D BE 23 25 8E 5E E........4..#%.^ 0060 12 B0 AD 32 86 B3 55 CE B4 78 0B 21 5C BE 88 BD ...2..U..x.!\... 0070 4B 04 49 3F B2 EA 2B 85 A9 D7 AB 37 99 3A 4E 7A K.I?..+....7.:Nz 0080 02 00 82 9B 43 F7 2E 2F 7C B3 75 E6 9E 4A 96 A6 ....C../|.u..J.. 0090 81 40 96 4E E4 3C D1 D8 04 06 64 F0 89 BD 80 57 .@.N.<....d....W 00A0 CA 0D 9B E2 5F 5F 36 62 C3 3E E2 F0 2E F8 C5 3D ....__6b.>.....= 00B0 16 CF 6E 12 08 6B 67 C8 B6 D1 03 0E 42 07 A7 9E ..n..kg.....B... 00C0 68 E6 69 7A A5 85 0D DD 1E A8 CC 29 8F 04 2F 43 h.iz.......)../C 00D0 48 16 23 97 C4 C2 EF A3 4B 89 0D 5B 8E 02 65 C4 H.#.....K..[..e. 00E0 FC 74 E1 66 C0 A2 AA 69 E9 72 60 68 63 22 7F B4 .t.f...i.r`hc". 00F0 9A 5A 84 E2 CB 5B D6 FC E2 60 B2 9E C3 C2 97 28 .Z...[...`.....( ------[ SMBus Device B01-D57 ]------ 0000 A7 F4 0C A6 49 29 C1 D0 8A 6B 53 42 AE A0 BF B4 ....I)...kSB.... 0010 F0 8F A4 A6 19 7A C3 AB BD 05 02 79 C0 97 F8 32 .....z.....y...2 0020 49 F1 44 CB C3 F4 FF 64 20 BD 13 61 6E 54 F8 C1 I.D....d ..anT.. 0030 95 31 75 0B 70 A2 7D 59 EC C8 95 69 28 5D 2C 63 .1u.p.}Y...i(],c 0040 EF 0D E8 40 B8 CB D4 0C 52 2B 70 83 97 F8 5F D3 ...@....R+p..._. 0050 B5 E0 47 24 CC 98 3B B7 C9 A6 CB 78 D1 18 66 B8 ..G$..;....x..f. 0060 AA A7 F6 35 A0 22 B7 17 63 D2 5F FD 3D 48 D7 F6 ...5."..c._.=H.. 0070 9D 10 67 22 AF B9 40 17 83 7A 53 6D 01 00 00 00 ..g"..@..zSm.... 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ Chips Found ]------ B00-D51: SPDB00-D52: SPDB00-D53: SPDB01-D51: uPI uP????B01-D52: uPI uP????B01-D53: uPI uP???? The MSI Overclocking Center show the values mention in the OP that are missing. Unfortunately MSI Core Center and Control Center is said not complatible with my Mobo CPUID HW Monitor sees some additional voltages. Txt file attached In the BIOS the values are not present but they are available in the setting to change HWMonitor.txtFetching info... Quote
Fiery Posted February 20, 2013 Posted February 20, 2013 Thank you for the data. On 2/20/2013 at 12:37 AM, DigitalFruit said: In the BIOS the values are not present but they are available in the setting to change I'm afraid that means those voltage rails cannot be monitored, but only their voltage levels can be adjusted. Hence a monitoring software cannot monitor those voltages. Quote
