fixed: Zephyrus Duo 16 7945HX/4090 problem with testing Aida64
Spotikach
Greetings. I purchased this laptop (ASUS ROG Zephyrus Duo 16 GX650PY-NM025X) and have problems with it. When running Aida64 stress test, the laptop immediately gets a blue screen and a dead keyboard driver after a system reboot. In support, Asus says that this is a problem with the Aida64 program.
I used the latest version of Aida64 6.90.6500
I would like to know if there are issues with CPU R-7945HX support.
The problem is massive. Already three laptops in this series have the same problems in the Aida64 test
  • Solution
Let me know if it helps.
Hello. Just got a new laptop, same configuration, only 4080 graphics card. No more blue screens and other errors when working with Aida64. The beta version works well. Thank you for helping resolve the issue.
Thank you for your feedback!
  • Fiery changed the title to fixed: Zephyrus Duo 16 7945HX/4090 problem with testing Aida64
