lz_hui Posted February 26, 2013 Posted February 26, 2013 Can not detect the motherboard temperature, the voltage detector is not normal. Motherboard model:H61M-S26 V6 (MS-7774) AIDA64 version:2.80.2327 http://cn.msi.com/product/mb/H61M-S26-V6.html Field ValueSensor Properties Sensor Type ITE IT8772F (ISA A30h)Chassis Intrusion Detected Yes Temperatures CPU 25 癈 (77 癋)CPU Package 26 癈 (79 癋)CPU IA Cores 25 癈 (77 癋)CPU GT Cores 26 癈 (79 癋)CPU #1 / Core #1 25 癈 (77 癋)CPU #1 / Core #2 24 癈 (75 癋)PCH Diode 43 癈 (109 癋)Aux 11 癈 (52 癋)WDC WD5000AAKX-00ERMA0 22 癈 (72 癋) Cooling Fans CPU 2184 RPM Voltage Values CPU Core 0.966 V+5 V 2.835 V+12 V 3.694 V Power Values CPU Package 5.23 WCPU IA Cores 2.79 W Field ValueMotherboard Properties Motherboard ID 63-0100-000001-00101111-101111-Chipset$1APTC013_BIOS DATE: 07/09/12 18:35:30 VER: 04.06.05Motherboard Name MSI H61M-S26 V6 (MS-7774) Front Side Bus Properties Bus Type BCLKReal Clock 100 MHzEffective Clock 100 MHz Memory Bus Properties Bus Type Dual DDR3 SDRAMBus Width 128-bitDRAM:FSB Ratio 20:3Real Clock 667 MHz (DDR)Effective Clock 1333 MHzBandwidth 21333 MB/s Chipset Bus Properties Bus Type Intel Direct Media Interface v2.0 Motherboard Manufacturer Company Name Micro-Star Int'l Co.,Ltd.Product Information http://www.msi.com/product/mb/BIOS Download http://www.msi.com/service/download/Driver Update http://www.aida64.com/driver-updatesBIOS Upgrades http://www.aida64.com/bios-updates Field ValueBIOS Properties BIOS Type AMI EFIBIOS Version 4.6.5System BIOS Date 07/09/2012Video BIOS Date 10/12/11 BIOS Manufacturer Company Name American Megatrends Inc.Product Information http://www.ami.com/amibiosBIOS Upgrades http://www.aida64.com/bios-updates Quote
Fiery Posted February 26, 2013 Posted February 26, 2013 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Based on that data we can calibrate sensor readings to better support your motherboard.Thanks, Fiery Quote
lz_hui Posted February 27, 2013 Author Posted February 27, 2013 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Based on that data we can calibrate sensor readings to better support your motherboard. Thanks, Fiery isasensordump.txt Quote
lz_hui Posted February 27, 2013 Author Posted February 27, 2013 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Based on that data we can calibrate sensor readings to better support your motherboard. Thanks, Fiery ------[ AIDA64 v2.80.2327 Beta ]------ ------[ Microsoft Windows 8 Enterprise 6.2.9200.16496 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-101111-Chipset$1APTC013_BIOS DATE: 07/09/12 18:35:30 VER: 04.06.05 Motherboard Model : MSI H61M-S26 V6 (MS-7774) Motherboard Chipset : Intel Cougar Point H61, Intel Ivy Bridge DMI MB Manufacturer : MSI DMI MB Product : H61M-S26 V6(MS-7774) DMI MB Version : 6.0 DMI MB Serial : To be filled by O.E.M. DMI SYS Manufacturer: To be filled by O.E.M. DMI SYS Product : To be filled by O.E.M. DMI SYS Version : To be filled by O.E.M. DMI SYS Serial : To be filled by O.E.M. DMI BIOS Version : 4.6.5 ITE 87xx Port = 2Eh ITE 87xx HWMonitor Port = 0A30h ITE 87xx Device ID = 8772h ITE 87xx Version = 00h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = FFFFh Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0A30 ]------ 0000 19 5D FD 00 00 00 00 00 00 80 ED 0F 30 FF 34 FF 0010 49 50 18 75 C7 00 82 00 FF 01 FF 19 A7 CE CE CE 0020 4F 86 FF FF 58 FF FF 8B 93 0C 00 1D FF FC 3F 3F 0030 2C B6 B5 0C 1D 60 E4 C8 05 22 C2 E0 19 1C 37 6C 0040 13 BB 08 AF 62 12 5F 40 AD 6A D4 00 FF FF FF FF 0050 FF CE 7F 7F 7F 40 B0 46 90 69 00 12 60 00 00 00 0060 7F 7F 7F 80 00 00 0F FF 7F 7F 7F 80 00 00 0F FF 0070 7F 7F 7F 80 00 00 0F FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF 00 00 00 00 02 30 01 02 01 00 20 0E 0090 FF 00 00 00 FF 00 00 00 40 00 00 00 00 B7 02 0F 00A0 B4 17 17 17 17 17 17 FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0029 002A 002B T: 12 0 29 T: 12 0 29 T: 12 0 28 T: 12 0 28 T: 12 0 31 T: 12 0 29 T: 12 0 27 T: 12 0 28 T: 12 0 28 T: 12 0 28 Reg$20 CPU Core: r = 79, r*0.016 = 1.26 Reg$21 CPU Aux: r = 134, r*0.016 = 2.14 Reg$22 +3.3 V: r = 255, r*0.016 = 4.08 Reg$23 +5 V: r = 255, r*0.016 = 4.08 Reg$24 +12 V: r = 88, r*0.016 = 1.41 Reg$25 -12 V: r = 255, r*0.016 = 4.08 Reg$26 -5 V: r = 255, r*0.016 = 4.08 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA> _TZ_.TZ01._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3030</DATA> _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : Quote
Fiery Posted February 27, 2013 Posted February 27, 2013 Thank you. Can you please check how many temperatures the BIOS Setup can monitor on the H/W Monitor or PC Health Status page? Please also let me know what voltage values you can see there. Quote
lz_hui Posted February 27, 2013 Author Posted February 27, 2013 Thank you. Can you please check how many temperatures the BIOS Setup can monitor on the H/W Monitor or PC Health Status page? Please also let me know what voltage values you can see there. Thanks !!! Quote
lz_hui Posted February 28, 2013 Author Posted February 28, 2013 Thank you. Can you please check how many temperatures the BIOS Setup can monitor on the H/W Monitor or PC Health Status page? Please also let me know what voltage values you can see there. Can you fix that ? Quote
Fiery Posted February 28, 2013 Posted February 28, 2013 Thank you for the photo. We'll fix the sensor information in the next AIDA64 beta. As soon as the new beta is available, I'll drop a message in this topic. Quote
lz_hui Posted March 4, 2013 Author Posted March 4, 2013 Thank you for the photo. We'll fix the sensor information in the next AIDA64 beta. As soon as the new beta is available, I'll drop a message in this topic. The Version 2.80.2334 beta is ok Quote
lz_hui Posted March 4, 2013 Author Posted March 4, 2013 Thank you for the photo. We'll fix the sensor information in the next AIDA64 beta. As soon as the new beta is available, I'll drop a message in this topic. Thanks !!! Quote
Fiery Posted March 4, 2013 Posted March 4, 2013 The Version 2.80.2334 beta is ok Thank you for the feedback Quote
