SSD Temperature not detected (Corsair Neutron GTX 240)
I have a Corsair Neutron GTX 240 SSD.  AIDA64 most recent version detects and reports data for SSD wherever AIDA64 detects hdds except that no temperature is reported by Computer / Sensor or by OSD or by Stability Test.  Nothing else is missing as far as I can tell.
To be precise: there is no sensor identified for ssd temperature, as opposed to havng an identified sensor but no reading.
SSD is connected direct to mb sata plug and is the system drive, letter c:/.
Speedfan and Cpuid HW Monitor do report temperature for the SSD.
Can you see any SMART attributes for your SSD on the Storage / SMART page in AIDA64?  If not, then try to enable the two RAID-related options in AIDA64 / main menu / File / Preferences / Stability, update AIDA64 to the latest beta (link below), and update Intel RST or RSTe drivers to the latest WHQL release (if you have an Intel AHCI or RAID controller in your system).
http://www.aida64.com/downloads/aida64extremebuild2327vtb1dhc3yjzip
Let me know if that helps.  If not, then we'll dig deeper ;)
SSD SMART is visible.  I enabled the RAID preferences anyway to check.  No change.   No RAID on system anyway
System is AMD not Intel. Has all lastest drivers, other than those that appear to be just to add Windows 8.  I'm running windows 7-64.
The beta download is an executable, not an installer  so I ran it from download folder.  No difference on SSD temp reading - none at all.
Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> SMART Dump.  Copy-paste the full results into this topic.
We'll analyze that data, and fix the bug in AIDA64.
Please note that since my original post, I moved two hdds to new external enclsure and lost SMART and temp on one.  Probably not the same issue as this but it is contained in this debug dump.  I posted the new enclosure isuue separately a few minutes ago.
------[ AIDA64 v2.80.2300 ]------
------[ Microsoft Windows 7 Home Premium 6.1.7601.18044 Service Pack 1 (64-bit) ]------
Motherboard ID      : 64-2001-000001-00101111-030811-ATHLON64$A1585000_BIOS DATE: 03/08/11 10:42:32 VER: 08.00.15
Motherboard Model   : Asus M4A87TD Evo
Motherboard Chipset : AMD 870, AMD K10
DMI MB Manufacturer : ASUSTeK Computer INC.
DMI MB Product      : M4A87TD EVO
DMI MB Version      : Rev 1.xx
DMI MB Serial       : MT7009028400376
DMI SYS Product     : System Product Name
DMI SYS Version     : System Version
DMI SYS Serial      : System Serial Number
DMI BIOS Version    : 2001
------[ PCI Devices ]------
B00-D11-F00 [1002-4391] [1002-4391] [CC0106]: ATI SB800 - SATA AHCI Controller
B00-D14-F01 [1002-439C] [1002-439C] [CC0101]: ATI SB800 - IDE Controller
B05-D00-F00 [197B-2361] [1043-843F] [CC0101]: JMicron JMB361 SATA-II AHCI Controller
------[ USB Devices ]------
[HID\VID_045E&PID_0745]: HID-compliant consumer control device
[HID\VID_045E&PID_0745]: HID-compliant device
[HID\VID_045E&PID_0745]: Microsoft USB Dual Receiver Wireless Keyboard (Mouse and Keyboard Center)
[HID\VID_045E&PID_0745]: Microsoft USB Dual Receiver Wireless Mouse (Mouse and Keyboard Center)
[uSB\VID_045E&PID_0745]: Microsoft Hardware USB Keyboard (0000.0012.0000.002.000.000.000.000.000)
[uSB\VID_045E&PID_0745]: Microsoft Hardware USB Mouse (0000.0012.0000.002.000.000.000.000.000)
[uSB\VID_045E&PID_0745]: Microsoft Mouse and Keyboard Detection Driver (USB) (Port_#0002.Hub_#0001)
[uSB\VID_045E&PID_0745]: USB Input Device (0000.0012.0000.002.000.000.000.000.000)
[uSB\VID_0971&PID_2007]: colormunki (Port_#0004.Hub_#0001)
[uSB\VID_0BDA&PID_0301]: USB Mass Storage Device (Port_#0004.Hub_#0001)
[uSB\VID_0CF3&PID_9271]: TP-LINK 150Mbps Wireless Lite N Adapter (Port_#0001.Hub_#0002)
[uSBSTOR\DISKGENERIC-USB3.0_CRW-CF/MD1.00]: Generic- USB3.0 CRW-CF/MD USB Device
[uSBSTOR\DISKGENERIC-USB3.0_CRW-MS___1.00]: Generic- USB3.0 CRW-MS USB Device
[uSBSTOR\DISKGENERIC-USB3.0_CRW-SD/MS1.00]: Generic- USB3.0 CRW-SD/MS USB Device
[uSBSTOR\DISKGENERIC-USB3.0_CRW-SD___1.00]: Generic- USB3.0 CRW-SD USB Device
[uSBSTOR\DISKGENERIC-USB3.0_CRW-SM/XD1.00]: Generic- USB3.0 CRW-SM/xD USB Device
------[ Windows Devices / IDE Controllers ]------
Driver Desc    : ATA Channel 0
Driver Date    : 6-21-2006
Driver Version : 6.1.7601.17514
Driver Provider: Microsoft
Driver Desc    : ATA Channel 1
Driver Desc    : ATA Channel 2
Driver Desc    : ATA Channel 3
Driver Desc    : Standard AHCI 1.0 Serial ATA Controller
Driver Desc    : Standard Dual Channel PCI IDE Controller
------[ Windows Devices / RAID/SCSI Controllers ]------
Driver Desc    : JMicron JMB36X Controller
Driver Date    : 5-19-2011
Driver Version : 1.17.63.1
Driver Provider: JMicron Technology Corp.
------[ SMART List ]------
<ORD>A0001</ORD><MODEL>Corsair Neutron GTX SSD</MODEL><SERIAL>130279060000975600AC</SERIAL><REV>M305</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\ide#diskcorsair_neutron_gtx_ssd_________________m305____#5&2a6a655c&0&3.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><PRIORITY>5</PRIORITY><MODSER>Corsair Neutron GTX SSD</MODSER><LASTTEMP>0</LASTTEMP>
<ORD>A0002</ORD><MODEL>WDC WD1002FAEX-00Z3A0</MODEL><SERIAL>WD-WCATR3367143</SERIAL><REV>05.01D05</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\ide#diskwdc_wd1002faex-00z3a0___________________05.01d05#5&dc2ac93&0&0.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><PRIORITY>5</PRIORITY><MODSER>WDC WD1002FAEX-00Z3A0</MODSER><LASTTEMP>32</LASTTEMP>
<ORD>A0003</ORD><MODEL>WDC WD1501FASS-00U0B0</MODEL><SERIAL>WD-WMAUR0301239</SERIAL><REV>01.00101</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\ide#diskwdc_wd1501fass-00u0b0___________________01.00101#5&4f70412&0&1.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><PRIORITY>5</PRIORITY><MODSER>WDC WD1501FASS-00U0B0</MODSER><LASTTEMP>34</LASTTEMP>
<ORD>A0004</ORD><MODEL>WDC WD2002FAEX-007BA0</MODEL><SERIAL>WD-WMAY01887309</SERIAL><REV>05.01D05</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\ide#diskwdc_wd2002faex-007ba0___________________05.01d05#5&17b0b4b7&0&2.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><PRIORITY>5</PRIORITY><MODSER>WDC WD2002FAEX-007BA0</MODSER><LASTTEMP>33</LASTTEMP>
<ORD>A0005</ORD><MODEL>ST31000340AS</MODEL><SERIAL>9QJ1WW62</SERIAL><REV>0958</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\scsi#disk&ven_&prod_st31000340as&rev_9085#5&1fe2f255&1&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><PRIORITY>5</PRIORITY><MODSER>ST31000340AS</MODSER>
<ORD>A0006</ORD><MODEL>WDC WD15EADS-00H7B0</MODEL><SERIAL>WD-WCAUP0015775</SERIAL><REV>05.00K05</REV><IDBUFSIZE>512</IDBUFSIZE><ATAPIDEV>0</ATAPIDEV><SMARTINFO>1</SMARTINFO><SMARTDEV>\\?\scsi#disk&ven_wdc&prod_wd15eads-00h7b0&rev_500.#5&1fe2f255&1&000100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}</SMARTDEV><SMARTDRIVE>0</SMARTDRIVE><PRIORITY>5</PRIORITY><MODSER>WDC WD15EADS-00H7B0</MODSER><LASTTEMP>32</LASTTEMP>
------[ SMART Device 0 ]------
0000  00 00                                -  04 00
0000  01 0F 00 A6 A6 00 00 00 00 00 00 00  -  01 06 00 00 00 00 00 00 00 00 00 00
0010  05 32 00 FD FD 00 00 00 00 00 00 00  -  05 24 00 00 00 00 00 00 00 00 00 00
0020  09 32 00 FD FD 00 00 00 00 00 00 00  -  09 00 00 00 00 00 00 00 00 00 00 00
0030  0C 32 00 64 64 7F 00 00 00 00 00 00  -  0C 14 00 00 00 00 00 00 00 00 00 00
0030  AB 32 00 FD FD 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0040  AC 32 00 FD FD 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0050  B5 32 00 FD FD 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0060  B6 32 00 FD FD 00 00 00 00 00 00 00  -  AB 00 00 00 00 00 00 00 00 00 00 00
0060  C2 02 00 1D 00 1D 00 25 00 14 00 00  -  AC 00 00 00 00 00 00 00 00 00 00 00
0070  C9 0E 00 64 64 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0080  CC 0E 00 64 64 00 00 00 00 00 00 00  -  B5 00 00 00 00 00 00 00 00 00 00 00
0090  E7 33 00 FD FD 00 00 00 00 00 00 00  -  B6 00 00 00 00 00 00 00 00 00 00 00
0090  EA 32 00 64 64 48 02 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00A0  F1 32 00 64 64 ED 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00B0  F2 32 00 64 64 3A 01 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00C0  FA 32 00 FD FD 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00C0  00 00 00 00 00 00 00 00 00 00 00 00  -  C2 00 00 00 00 00 00 00 00 00 00 00
00D0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00E0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00F0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0100  00 00 00 00 00 00 00 00 00 00 00 00  -  C9 00 00 00 00 00 00 00 00 00 00 00
0110  00 00 00 00 00 00 00 00 00 00 00 00  -  CC 00 00 00 00 00 00 00 00 00 00 00
0120  00 00 00 00 00 00 00 00 00 00 00 00  -  E7 0A 00 00 00 00 00 00 00 00 00 00
0120  00 00 00 00 00 00 00 00 00 00 00 00  -  EA 00 00 00 00 00 00 00 00 00 00 00
0130  00 00 00 00 00 00 00 00 00 00 00 00  -  F1 00 00 00 00 00 00 00 00 00 00 00
0140  00 00 00 00 00 00 00 00 00 00 00 00  -  F2 00 00 00 00 00 00 00 00 00 00 00
0150  00 00 00 00 00 00 00 00 00 00 00 00  -  FA 00 00 00 00 00 00 00 00 00 00 00
0150  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0160  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0170  00 00 00 00 00 19 02 00 01 00 01 05  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  01 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0190  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01A0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01B0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01C0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01D0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01E0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 45                    -  00 00 00 00 00 D2
------[ SMART Device 1 ]------
0000  10 00                                -  10 00
0000  01 2F 00 C8 C8 00 00 00 00 00 00 00  -  01 33 C8 C8 C8 C8 00 00 00 00 00 00
0010  03 27 00 AE AC B3 10 00 00 00 00 00  -  03 15 00 00 00 00 00 00 00 00 00 00
0020  04 32 00 63 63 9F 06 00 00 00 00 00  -  04 00 00 00 00 00 00 00 00 00 00 00
0030  05 33 00 C8 C8 00 00 00 00 00 00 00  -  05 8C 00 00 00 00 00 00 00 00 00 00
0030  07 2E 00 64 FD 00 00 00 00 00 00 00  -  07 00 64 64 64 64 00 00 00 00 00 00
0040  09 32 00 59 59 AD 1F 00 00 00 00 00  -  09 00 00 00 00 00 00 00 00 00 00 00
0050  0A 32 00 64 64 00 00 00 00 00 00 00  -  0A 00 00 00 00 00 00 00 00 00 00 00
0060  0B 32 00 64 64 00 00 00 00 00 00 00  -  0B 00 00 00 00 00 00 00 00 00 00 00
0060  0C 32 00 63 63 52 06 00 00 00 00 00  -  0C 00 00 00 00 00 00 00 00 00 00 00
0070  C0 32 00 C8 C8 F8 00 00 00 00 00 00  -  C0 00 00 00 00 00 00 00 00 00 00 00
0080  C1 32 00 C8 C8 A6 05 00 00 00 00 00  -  C1 00 00 00 00 00 00 00 00 00 00 00
0090  C2 22 00 73 66 20 00 00 00 00 00 00  -  C2 00 00 00 00 00 00 00 00 00 00 00
0090  C4 32 00 C8 C8 00 00 00 00 00 00 00  -  C4 00 00 00 00 00 00 00 00 00 00 00
00A0  C5 32 00 C8 C8 00 00 00 00 00 00 00  -  C5 00 00 00 00 00 00 00 00 00 00 00
00B0  C6 30 00 C8 C8 00 00 00 00 00 00 00  -  C6 00 00 00 00 00 00 00 00 00 00 00
00C0  C7 32 00 C8 C7 F6 04 00 00 00 00 00  -  C7 00 00 00 00 00 00 00 00 00 00 00
00C0  C8 08 00 C8 C8 00 00 00 00 00 00 00  -  C8 00 C8 C8 C8 C8 00 00 00 00 00 00
0100  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0110  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0120  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0130  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0140  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0170  84 00 A0 41 01 7B 03 00 01 00 02 C2  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  05 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  01 04 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 1F                    -  00 00 00 00 00 ED
------[ SMART Device 2 ]------
0000  10 00                                -  10 00
0000  01 2F 00 C8 C8 00 00 00 00 00 00 00  -  01 33 C8 C8 C8 C8 C8 C8 C8 00 00 00
0010  03 27 00 32 28 BD 38 00 00 00 00 00  -  03 15 00 00 00 00 00 00 00 00 00 00
0020  04 32 00 63 63 83 06 00 00 00 00 00  -  04 00 00 00 00 00 00 00 00 00 00 00
0030  07 2E 00 C8 C8 00 00 00 00 00 00 00  -  07 00 C8 C8 C8 C8 C8 C8 C8 00 00 00
0040  09 32 00 59 59 0A 21 00 00 00 00 00  -  09 00 00 00 00 00 00 00 00 00 00 00
0060  0C 32 00 63 63 7A 06 00 00 00 00 00  -  0C 00 00 00 00 00 00 00 00 00 00 00
0070  C0 32 00 C8 C8 0F 02 00 00 00 00 00  -  C0 00 00 00 00 00 00 00 00 00 00 00
0080  C1 32 00 B5 B5 3B E8 00 00 00 00 00  -  C1 00 00 00 00 00 00 00 00 00 00 00
0090  C2 22 00 76 61 22 00 00 00 00 00 00  -  C2 00 00 00 00 00 00 00 00 00 00 00
00C0  C7 32 00 C8 C8 00 00 00 00 00 00 00  -  C7 00 00 00 00 00 00 00 00 00 00 00
00C0  C8 08 00 C8 C8 00 00 00 00 00 00 00  -  C8 00 C8 C8 C8 C8 C8 C8 C8 00 00 00
0170  84 00 94 5C 01 7B 03 00 01 00 02 FF  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  05 10 01 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  01 07 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 81                    -  00 00 00 00 00 55
------[ SMART Device 3 ]------
0000  10 00                                -  10 00
0000  01 2F 00 C8 C8 00 00 00 00 00 00 00  -  01 33 C8 C8 C8 C8 C8 C8 C8 C8 00 00
0010  03 27 00 FD FD CA 21 00 00 00 00 00  -  03 15 00 00 00 00 00 00 00 00 00 00
0020  04 32 00 64 64 D0 03 00 00 00 00 00  -  04 00 00 00 00 00 00 00 00 00 00 00
0030  07 2E 00 C8 C8 00 00 00 00 00 00 00  -  07 00 C8 C8 C8 C8 C8 C8 C8 C8 00 00
0040  09 32 00 5D 5D 46 15 00 00 00 00 00  -  09 00 00 00 00 00 00 00 00 00 00 00
0060  0C 32 00 64 64 C7 03 00 00 00 00 00  -  0C 00 00 00 00 00 00 00 00 00 00 00
0070  C0 32 00 C8 C8 A3 00 00 00 00 00 00  -  C0 00 00 00 00 00 00 00 00 00 00 00
0080  C1 32 00 C8 C8 2C 03 00 00 00 00 00  -  C1 00 00 00 00 00 00 00 00 00 00 00
0090  C2 22 00 77 60 21 00 00 00 00 00 00  -  C2 00 00 00 00 00 00 00 00 00 00 00
00C0  C8 08 00 C8 C8 00 00 00 00 00 00 00  -  C8 00 C8 C8 C8 C8 C8 C8 C8 C8 00 00
0170  84 00 54 6F 01 7B 03 00 01 00 02 FF  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  05 22 01 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  01 08 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 72                    -  00 00 00 00 00 FD
------[ SMART Device 4 ]------
0000  00 00                                -  00 00
0000  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0010  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0020  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0030  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0040  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0050  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0060  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0070  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0080  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0090  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00A0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00B0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
00C0  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
0170  00 00 00 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 00                    -  00 00 00 00 00 00
------[ SMART Device 5 ]------
0000  10 00                                -  10 00
0000  01 2F 00 C8 C8 EF 00 00 00 00 00 00  -  01 33 C8 C8 C8 C8 C8 C8 C8 C8 00 00
0010  03 27 00 64 FD 00 00 00 00 00 00 00  -  03 15 00 00 00 00 00 00 00 00 00 00
0020  04 32 00 61 61 3D 0C 00 00 00 00 00  -  04 00 00 00 00 00 00 00 00 00 00 00
0030  07 2E 00 64 FD 00 00 00 00 00 00 00  -  07 00 64 64 64 64 64 64 64 64 00 00
0040  09 32 00 64 64 03 00 00 00 00 00 00  -  09 00 00 00 00 00 00 00 00 00 00 00
0060  0C 32 00 62 62 93 0A 00 00 00 00 00  -  0C 00 00 00 00 00 00 00 00 00 00 00
0070  C0 32 00 C8 C8 C2 00 00 00 00 00 00  -  C0 00 00 00 00 00 00 00 00 00 00 00
0080  C1 32 00 C7 C7 07 0C 00 00 00 00 00  -  C1 00 00 00 00 00 00 00 00 00 00 00
0090  C2 22 00 78 68 20 00 00 00 00 00 00  -  C2 00 00 00 00 00 00 00 00 00 00 00
00C0  C8 08 00 C7 C5 D2 00 00 00 00 00 00  -  C8 00 C8 C8 C8 C8 C8 C7 C8 C8 00 00
0170  84 00 5C 94 01 7B 03 00 01 00 02 FF  -  00 00 00 00 00 00 00 00 00 00 00 00
0180  05 B1 01 00 00 00 00 00 00 00 00 00  -  00 00 00 00 00 00 00 00 00 00 00 00
01F0  00 00 00 00 00 AE                    -  00 00 00 00 00 1E
Thank you, the bug will be fixed in the next AIDA64 beta release.  Please note that upgrading to a new AIDA64 beta works as:
1) Close AIDA64
2) Download the beta ZIP package
3) Extract the ZIP archive to the existing installation folder of AIDA64, and let it overwrite any existing files
SSD temp is now reported.
One quirk:  The first time I started AIDA64 after instaling the beta, it added the SSD temperature to OSD alreadfy selected and placed it just above the hdd temps.  I had customized the OSD order and selections so no reason to expect that it would do this.
I had also use "configure" to customize to shorter hdd labels in OSD.
When the ssd was added, the ssd temp in OSD copied a label from one hdd and all the custom hdd labels were scrambled.  Same labels that I used, but on the wrong drives.  After re-edit they do stay put.
There is now a pop up  while AIDA64 starts that didn't appear before that says "detecting sensor information."
Thank you for the feedback. I'm sorry for the mixup about the HDD/SSD temperature labels, that was a one-time issue that only happened because of the bug fix.  As for the "Detecting sensor information" message, that could be displayed when AIDA64 is started minimized or hidden, and the "Remember last page" option is enabled, and the last page you've used was the Sensor page ;)
Yes, that's exactly the settings I had.
