Kurgan Posted September 22, 2023 Posted September 22, 2023 Sometime in the last 24 hours, AIDA 64 stopped reading my T-Sensor on my Asus ROG X570 Crosshair VIII Hero motherboard. I confirmed the sensor is still active and working, as my fan control software uses this temp sensor to read my water temp for my custom loop. Quote
Kurgan Posted September 22, 2023 Author Posted September 22, 2023 I am so confused, I don't even see it listed anywhere anymore... I even installed an old version. Quote
Kurgan Posted September 23, 2023 Author Posted September 23, 2023 I think I might have a sensor going bad... it automagically reappeared this morning. Quote
Corotan Posted September 23, 2023 Posted September 23, 2023 (edited) I have Asus ROG X570 Crosshair VIII Hero wi-fi motherboard and my sensor panel stopped working this morning. Aida hangs at detecting sensors. It might not be your sensor going bad. Status update: I did a power supply shutdown and Aida detected the sensors successfully and the sensor panel reappeared. Edited September 23, 2023 by Corotan Status update Quote
Kurgan Posted September 29, 2023 Author Posted September 29, 2023 @Corotan Yeah, I did the same, and it worked for several days, and then disappeared again. Quote
Kurgan Posted September 30, 2023 Author Posted September 30, 2023 So it seems, that randomly, every couple of days, my sensor panel will read NaN °C from the "T_Sensor" under temperatures. Restarting AIDA 64 Extreme does not solve it. Rebooting the PC doesn't fix it, even powering off the PC and restarting does not solve it issue. I have even reinstalled AIDA 64, and still got the same result. Powering down my PC and turning off the power supply, waiting a few seconds, then powering back up does solve the issue for a day or two. As mentioned above, this is with my Asus ROG X570 Crosshair VIII Hero motherboard, I am using the latest version of AIDA 64 Extreme (registered) and Windows 10. Quote
Kurgan Posted October 13, 2023 Author Posted October 13, 2023 HAH! just read the change notes: fixed: motherboard specific sensor info for Asus Pro WS X570-ACE, ROG Crosshair VIII Series Quote
Kurgan Posted October 15, 2023 Author Posted October 15, 2023 Unfortunately it still happened. the recent update did not fix my issue Quote
