ulicee Posted September 30, 2023 Posted September 30, 2023 Hello! I'm having trouble seeing the AIO pump, fans and coolant sensors in AIDA64. The AiO model is a EVGA CLC 240mm. Both HWiNFO64 and Argus Monitor see the sensors that AIDA64 doesn't. HWiNFO64 sees it as NZXT Kraken [...]: Argus Monitor sees it as EVGA CLC: I've ticked the "Corsair Link sensor support" box in AIDA64 Preferences - Stability page. Also, EVGA Flow Control application is not running. When it runs sensors are not visible in any app (AIDA64, HWiNFO64 or Argus Monitor). Many thanks for your help! Quote
Fiery Posted October 2, 2023 Posted October 2, 2023 On 10/1/2023 at 1:01 AM, ulicee said: Hello! I'm having trouble seeing the AIO pump, fans and coolant sensors in AIDA64. The AiO model is a EVGA CLC 240mm. Both HWiNFO64 and Argus Monitor see the sensors that AIDA64 doesn't. HWiNFO64 sees it as NZXT Kraken [...]: Argus Monitor sees it as EVGA CLC: I've ticked the "Corsair Link sensor support" box in AIDA64 Preferences - Stability page. Also, EVGA Flow Control application is not running. When it runs sensors are not visible in any app (AIDA64, HWiNFO64 or Argus Monitor). Many thanks for your help! Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
ulicee Posted October 2, 2023 Author Posted October 2, 2023 Here attached. AIDA64 System Debug - USB Dump.txt Quote
