objecttothis Posted October 4, 2023 Posted October 4, 2023 I see a couple of other threads similar to this but I didn't want to necro them. I attached the EC Dump. The sensor reports in L/M in the BIOS and in HWiNFO, so I know that it's working. I'm using an Alphacool ES flow and temperature indicator with RPM-signal (https://shop.alphacool.com/en/shop/controllers-and-sensors/flow-sensor/17558-alphacool-es-flow-and-temperature-indicator-highflow-with-rpm-signal) connected to the FLOW header on the motherboard. ecdump.txt Quote
Fiery Posted October 4, 2023 Posted October 4, 2023 19 minutes ago, objecttothis said: I see a couple of other threads similar to this but I didn't want to necro them. I attached the EC Dump. The sensor reports in L/M in the BIOS and in HWiNFO, so I know that it's working. I'm using an Alphacool ES flow and temperature indicator with RPM-signal (https://shop.alphacool.com/en/shop/controllers-and-sensors/flow-sensor/17558-alphacool-es-flow-and-temperature-indicator-highflow-with-rpm-signal) connected to the FLOW header on the motherboard. Make sure to enable both these options in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes. Embedded Controller (EC) support Embedded Controller (EC) bank switching Quote
objecttothis Posted October 4, 2023 Author Posted October 4, 2023 Both are already enabled. I restarted AIDA64 and redetected sensors but flow is still missing. Quote
objecttothis Posted October 5, 2023 Author Posted October 5, 2023 On 10/4/2023 at 4:59 PM, Fiery said: Make sure to enable both these options in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes. Embedded Controller (EC) support Embedded Controller (EC) bank switching @Fiery I just installed the 6.92.6610 beta as I see there is some support added for a few new sensors. After installing I restarted, but unfortunately the flow sensor is still missing. Quote
objecttothis Posted October 5, 2023 Author Posted October 5, 2023 Looks like this guy is reporting the same issue: Quote
objecttothis Posted October 5, 2023 Author Posted October 5, 2023 In case it's helpful, here is the ISA sensor dump as well. isasensordump.txt Quote
objecttothis Posted October 8, 2023 Author Posted October 8, 2023 On 10/6/2023 at 1:52 PM, Marda89 said: I have the same problem: I wonder if the sensor on the X570 and X670E Hero boards are the same. I would guess they are, but I'm not sure. Quote
objecttothis Posted October 12, 2023 Author Posted October 12, 2023 @Fiery I just saw that 6.92.6614 beta has been released with one of the release notes reading "fixed: motherboard specific sensor info for Asus Pro WS X570-ACE, ROG Crosshair VIII Series" so I downloaded and installed it then restarted the computer. Unfortunately AIDA64 still isn't seeing the flow sensor on the Asus ROG Crosshair VIII Hero. Is there anything I need to do differently on my end or diagnostic data items that can help determine the cause of the problem? Quote
