fixed: missing GPU temp sensor on iMac Late 2012
hi,
I've recently installed AIDA64 on a iMac Late 2012 set with Windows 8. everything looks good except one thing : if I turn on Apple SMC support, I loose the GPU diode (1st screenshot).
if I turn it off, it reappear but I miss the other sensors brought by SMC (2nd screenshot).
is there a way to have all ?
version 2.70.2200 does not have this problem. GPU sensor type is Driver  (NV-DRV) and since 2.80.xxxx it's Diode  (NV-Diode) if it could help...  ;)
Please upgrade to the latest beta version of AIDA64 Extreme Edition available at:
http://www.aida64.com/downloads/aida64extremebuild2406twdq1v8hcszip
Let me know if it helps.  It would also be a huge help for us if you could create an ISA Sensor Dump using this beta release, and copy-paste the results into this topic.  You can create such dump by right-clicking on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump.
GPU Diode came back with this revision but the value isn't good (value brought by Apple SMC). the one provided by 2.70.2200 (NV-DRV) was right (GPU-Z monitors the good one for example).
ISA Dump :
------[ AIDA64 v2.85.2406 Beta ]------
------[ Microsoft Windows 8 Enterprise 6.2.9200.16496 (64-bit) ]------
Motherboard ID      : <DMI>
Motherboard Model   : Apple iMac (Mac-FC02E91DDD3FA6A4)
Motherboard Chipset : Intel Panther Point Z77, Intel Ivy Bridge
DMI MB Manufacturer : Apple Inc.
DMI MB Product      : Mac-FC02E91DDD3FA6A4
DMI MB Version      : iMac13,2
DMI MB Serial       :
DMI SYS Manufacturer: Apple Inc.
DMI SYS Product     : iMac13,2
DMI SYS Version     : 1.0
DMI SYS Serial      :
DMI BIOS Version    : IM131.88Z.010A.B05.1211151146
ITE 87xx Port           = 00h
ITE 87xx Device ID      = 0000h
ITE 87xx Version        = 00h
Winbond SuperIO Port              = 00h
Winbond SuperIO HWMonitor Port/60 = 0000h
Winbond SuperIO HWMonitor Port/64 = 0000h
Winbond SuperIO Device ID         = FFFFh
Fintek SuperIO Device ID      = 0000h
LPC47 SuperIO Device ID      = FFFFh
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
------[ Apple SMC ]------
SMC Version: 2.17.15.0.0.20
Fan Count: 1
Fan #0 Speed: 1196 RPM  (ID = "Main")
Temperature "TA0P": 16 C
Temperature "TA0S": < Failed >
Temperature "TA1P": < Failed >
Temperature "TA1S": < Failed >
Temperature "TA2S": < Failed >
Temperature "TA3S": < Failed >
Temperature "TALP": < Failed >
Temperature "TB0T": < Failed >
Temperature "TB1S": < Failed >
Temperature "TB1T": < Failed >
Temperature "TB2S": < Failed >
Temperature "TB2T": < Failed >
Temperature "TB3T": < Failed >
Temperature "TC0C": < Failed >
Temperature "TC0D": < Failed >
Temperature "TC0F": 206 C
Temperature "TC0H": < Failed >
Temperature "TC0P": 49 C
Temperature "TC1C": < Failed >
Temperature "TC1D": < Failed >
Temperature "TC2C": < Failed >
Temperature "TC2D": < Failed >
Temperature "TC3C": < Failed >
Temperature "TC3D": < Failed >
Temperature "TCAC": < Failed >
Temperature "TCAD": < Failed >
Temperature "TCAG": < Failed >
Temperature "TCAH": < Failed >
Temperature "TCBC": < Failed >
Temperature "TCBD": < Failed >
Temperature "TCBG": < Failed >
Temperature "TCBH": < Failed >
Temperature "TCFP": < Failed >
Temperature "TG0D": 64 C
Temperature "TG0F": 64 C
Temperature "TG0H": < Failed >
Temperature "TG0P": < Failed >
Temperature "TG0T": 0 C
Temperature "TG1H": < Failed >
Temperature "TH0P": 1 C
Temperature "TH1P": 129 C
Temperature "TH2P": < Failed >
Temperature "TH3P": < Failed >
Temperature "TH4P": < Failed >
Temperature "THTG": < Failed >
Temperature "TL0P": 19 C
Temperature "TM0P": 40 C
Temperature "TM0S": < Failed >
Temperature "TM1P": 32 C
Temperature "TM1S": < Failed >
Temperature "TM2P": 35 C
Temperature "TM2S": < Failed >
Temperature "TM3P": 38 C
Temperature "TM3S": < Failed >
Temperature "TM4P": < Failed >
Temperature "TM5P": < Failed >
Temperature "TM6P": < Failed >
Temperature "TM7P": < Failed >
Temperature "TM8P": < Failed >
Temperature "TM8S": < Failed >
Temperature "TM9P": < Failed >
Temperature "TM9S": < Failed >
Temperature "TMA1": < Failed >
Temperature "TMA2": < Failed >
Temperature "TMA3": < Failed >
Temperature "TMA4": < Failed >
Temperature "TMAP": < Failed >
Temperature "TMAS": < Failed >
Temperature "TMB1": < Failed >
Temperature "TMB2": < Failed >
Temperature "TMB3": < Failed >
Temperature "TMB4": < Failed >
Temperature "TMBS": < Failed >
Temperature "TN0C": < Failed >
Temperature "TN0D": < Failed >
Temperature "TN0H": < Failed >
Temperature "TN0P": < Failed >
Temperature "TN1P": < Failed >
Temperature "TO0P": < Failed >
Temperature "TS0C": < Failed >
Temperature "TTF0": < Failed >
Temperature "TV0P": < Failed >
Temperature "TVFP": < Failed >
Temperature "TW0P": < Failed >
Temperature "Te1S": < Failed >
Temperature "Te2S": < Failed >
Temperature "Te3S": < Failed >
Temperature "Te4S": < Failed >
Temperature "Te5S": < Failed >
Temperature "Th0H": < Failed >
Temperature "Th0P": < Failed >
Temperature "Th0S": < Failed >
Temperature "Th1H": < Failed >
Temperature "Th2H": < Failed >
Temperature "ThFH": < Failed >
Temperature "Tm0P": 39 C
Temperature "Tp0C": < Failed >
Temperature "Tp0P": < Failed >
Temperature "Tp1C": < Failed >
Temperature "TpFP": < Failed >
Temperature "Tp1P": < Failed >
Temperature "Ts0P": < Failed >
Temperature "Ts0S": < Failed >
Temperature "Ts1P": < Failed >
Temperature "Tv0S": < Failed >
Temperature "Tv1S": < Failed >
Voltage "VC0C": 51230 V
Voltage "VC0c": < Failed >
Voltage "VCAB": < Failed >
Voltage "VCAC": < Failed >
Voltage "VCBB": < Failed >
Voltage "VCBC": < Failed >
Voltage "VD0R": < Failed >
Voltage "VD5R": < Failed >
Voltage "VG0C": 12320 V
Voltage "VG0R": < Failed >
Voltage "VG0r": < Failed >
Voltage "VH1Z": < Failed >
Voltage "VH2Z": < Failed >
Voltage "VH3Z": < Failed >
Voltage "VH4Z": < Failed >
Voltage "VH5Z": < Failed >
Voltage "VM1S": < Failed >
Voltage "VM2S": < Failed >
Voltage "VN0C": < Failed >
Voltage "VN0R": < Failed >
Voltage "VO0Z": < Failed >
Voltage "VP0R": < Failed >
Voltage "VS1C": < Failed >
Voltage "VS2C": < Failed >
Voltage "VS8C": < Failed >
Voltage "Ve1S": < Failed >
Voltage "Ve2S": < Failed >
Voltage "Ve3S": < Failed >
Voltage "Ve4S": < Failed >
Voltage "VeAS": < Failed >
Voltage "VeBS": < Failed >
Voltage "Vp0C": < Failed >
Current "IB0R": < Failed >
Current "IC0C": 32263 A
Current "IC0R": < Failed >
Current "IC1C": < Failed >
Current "IC2C": < Failed >
Current "ICAB": < Failed >
Current "ICAC": < Failed >
Current "ICBB": < Failed >
Current "ICBC": < Failed >
Current "ID0R": < Failed >
Current "ID5R": < Failed >
Current "IG0C": 37636 A
Current "IG0R": < Failed >
Current "IG0r": < Failed >
Current "IG1C": < Failed >
Current "IH1Z": < Failed >
Current "IH2Z": < Failed >
Current "IH3Z": < Failed >
Current "IH4Z": < Failed >
Current "IH5Z": < Failed >
Current "IM0R": 29186 A
Current "IMAS": < Failed >
Current "IMBS": < Failed >
Current "IN0C": < Failed >
Current "IN0R": < Failed >
Current "IN1C": < Failed >
Current "IN1R": 27419 A
Current "IO0Z": < Failed >
Current "IP0R": < Failed >
Current "IS1C": < Failed >
Current "IS2C": < Failed >
Current "Ic0R": < Failed >
Current "Ie1S": < Failed >
Current "Ie2S": < Failed >
Current "Ie3S": < Failed >
Current "Ie4S": < Failed >
Current "IeAS": < Failed >
Current "IeBS": < Failed >
Current "Ip0C": < Failed >
Current "Ip1M": < Failed >
Current "Ip2M": < Failed >
Current "Ip3M": < Failed >
Current "Ip4M": < Failed >
Current "Ip5M": < Failed >
Current "Ip6M": < Failed >
Current "Ip7M": < Failed >
Current "Ip8M": < Failed >
Power "PC0C": 62721 W
Power "PC0c": < Failed >
Power "PD0R": < Failed >
Power "PD5R": < Failed >
Power "PDMR": < Failed >
Power "PDTR": 14870 W
Power "PG0R": < Failed >
Power "PZ0E": 40 W
Power "PZ0G": 18956 W
Thank you for the feedback.  We'll keep on working more on the Apple SMC module throghout April, and we'll add even more readings if possible.
