Can anyoneone help me? when i enable ax206 lcd support it says usb device 1908-0102 not found what to do :'')
6 minutes ago, joy537 said:
Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
  • 3 weeks later...
Hi, have same problem/ Dump:
------[ Versions ]------
Program Version : AIDA64 Business v7.00.6700
BenchDLL Version: 4.6.889.8-x64
Windows Version : Microsoft Windows 10 Home Single Language 10.0.19045.3570 (64-bit)
GetProductInfo  : 0x00000064
Motherboard ID      : 63-0100-000001-00101111-122418-Chipset$0AAAA000_BIOS DATE: 07/16/22 15:01:20 VER: VA.H1
Motherboard Model   : MSI B450-A Pro (MS-7B86)
Motherboard Chipset : AMD B450, AMD Taishan, AMD K17 IMC
DMI MB Manufacturer : Micro-Star International Co., Ltd
DMI MB Product      : B450-A PRO (MS-7B86)
DMI MB Version      : 2.0
DMI MB Serial       : J116603241
DMI SYS Manufacturer: Micro-Star International Co., Ltd
DMI SYS Product     : MS-7B86
DMI SYS Version     : 2.0
DMI SYS Serial      : To be filled by O.E.M.
DMI BIOS Version    : A.H1
------[ USB Devices ]------
Расширяемый хост-контроллер AMD USB 3.10 — 1.10 (Майкрософт)
- [Port 1] < No Device Connected >
- [Port 2] < No Device Connected >
- [Port 3] < No Device Connected >
- [Port 4] < No Device Connected >
- [Port 5] SmatCool (SmatCool)
- [Port 6] Logi USB Camera (C270 HD WebCam)
- - Logi C270 HD WebCam
- - - Микрофон (Logi C270 HD WebCam)
- [Port 7] < No Device Connected >
- [Port 8] < No Device Connected >
- [Port 9] < No Device Connected >
- [Port 10] < No Device Connected >
- [Port 11] Составное USB устройство (USB DEVICE)
- - USB-устройство ввода
- - - HID-совместимое устройство управления
- - - HID-совместимое устройство, определенное поставщиком
- [Port 12] Составное USB устройство (USB Device)
- - - Клавиатура HID
- - - HID-совместимая мышь
- - - HID-совместимый системный контроллер
- [Port 13] Составное USB устройство (USB Device)
- [Port 14] < No Device Connected >
Расширяемый хост-контроллер AMD USB 3.0 — 1.0 (Майкрософт)
- [Port 1] Запоминающее устройство для USB (Ext HDD 1021)
- - WD Ext HDD 1021 USB Device
- [Port 2] USB-SERIAL CH340 (COM3) (USB2.0-Serial)
- [Port 5] < No Device Connected >
- [Port 6] < No Device Connected >
------[ SmatCool]------
Device Description   : SmatCool
Device ID            : 2A55-9990
Device Class         : DC / A0 (Diagnostic Device)
Device Protocol      : B0
Revision             : 0200h
Manufacturer         : QTKeJi.Ltd
Product              : SmatCool
Serial Number        : 20221212
Supported USB Version: 2.00
Current Speed        : Full  (USB 1.1)
------[ Logi USB Camera (C270 HD WebCam)]------
Device Description   : Logi USB Camera (C270 HD WebCam)
Device ID            : 046D-0825
Device Class         : EF / 02 (Interface Association Descriptor)
Device Protocol      : 01
Revision             : 0012h
Serial Number        : 4E503700
Current Speed        : High  (USB 2.0)
------[ Составное USB устройство]------
Device Description   : Составное USB устройство
Device ID            : 2E97-1001
Device Class         : 03 / 00 (Human Interface Device)
Device Protocol      : 00
Revision             : 0019h
Manufacturer         : SONiX
Product              : USB DEVICE
Device ID            : 09DA-FA34
Device Class         : 03 / 01 (Human Interface Device)
Revision             : 001Bh
Manufacturer         : COMPANY
Product              : USB Device
Supported USB Version: 1.10
Device ID            : 09DA-50FD
Revision             : 00D1h
------[ Запоминающее устройство для USB]------
Device Description   : Запоминающее устройство для USB
Device ID            : 1058-1021
Device Class         : 08 / 06 (Mass Storage)
Device Protocol      : 50
Revision             : 2021h
Manufacturer         : Western Digital
Product              : Ext HDD 1021
Serial Number        : 5743433245354C4C45585341
------[ USB-SERIAL CH340 (COM3)]------
Device Description   : USB-SERIAL CH340 (COM3)
Device ID            : 1A86-7523
Device Class         : FF / 00
Revision             : 0262h
Product              : USB2.0-Serial
------[ DevClass / USB Hubs ]------
<DESC>Корневой USB-концентратор (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&1d428f36&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>23</DEVINST><INSTANCE>USB\ROOT_HUB30\5&1D428F36&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Корневой USB-концентратор (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&1fe43c1&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>24</DEVINST><INSTANCE>USB\ROOT_HUB30\5&1FE43C1&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
------[ DevClass / USB Devices ]------
<DESC>Составное USB устройство</DESC><DEVPATH>\\?\usb#vid_09da&pid_50fd#6&2e177b67&0&13#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>25</DEVINST><INSTANCE>USB\VID_09DA&PID_50FD\6&2E177B67&0&13</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000D</ADDR><REV>00=1</REV>
<DESC>USB-SERIAL CH340 (COM3)</DESC><DEVPATH>\\?\usb#vid_1a86&pid_7523#6&2f1ce26c&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>26</DEVINST><INSTANCE>USB\VID_1A86&PID_7523\6&2F1CE26C&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0262</REV>
<DESC>Составное USB устройство</DESC><DEVPATH>\\?\usb#vid_2e97&pid_1001#6&2e177b67&0&11#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>27</DEVINST><INSTANCE>USB\VID_2E97&PID_1001\6&2E177B67&0&11</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000B</ADDR><REV>0019</REV>
<DESC>SmatCool</DESC><DEVPATH>\\?\usb#vid_2a55&pid_9990#20221212#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>28</DEVINST><INSTANCE>USB\VID_2A55&PID_9990\20221212</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV>
<DESC>Составное USB устройство</DESC><DEVPATH>\\?\usb#vid_09da&pid_fa34#6&2e177b67&0&12#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>29</DEVINST><INSTANCE>USB\VID_09DA&PID_FA34\6&2E177B67&0&12</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000C</ADDR><REV>001;</REV>
<DESC>Запоминающее устройство для USB</DESC><DEVPATH>\\?\usb#vid_1058&pid_1021#5743433245354c4c45585341#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>30</DEVINST><INSTANCE>USB\VID_1058&PID_1021\5743433245354C4C45585341</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>2021</REV>
<DESC>Logi USB Camera (C270 HD WebCam)</DESC><DEVPATH>\\?\usb#vid_046d&pid_0825#4e503700#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>31</DEVINST><INSTANCE>USB\VID_046D&PID_0825\4E503700</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000006</ADDR><REV>0012</REV>
------[ DevClass / Human Interface Devices ]------
<DESC>HID-совместимая мышь</DESC><DEVPATH>\\?\hid#saitekmouse#2&fb7b623&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>3</DEVINST><INSTANCE>HID\SAITEKMOUSE\2&FB7B623&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000001</ADDR>
<DESC>Клавиатура HID</DESC><DEVPATH>\\?\hid#vid_09da&pid_50fd&mi_00#8&1c5841e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>4</DEVINST><INSTANCE>HID\VID_09DA&PID_50FD&MI_00\8&1C5841E&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000001</ADDR><REV>00=1</REV>
<DESC>Клавиатура HID</DESC><DEVPATH>\\?\hid#vid_09da&pid_fa34&mi_00#8&b9e70fc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>5</DEVINST><INSTANCE>HID\VID_09DA&PID_FA34&MI_00\8&B9E70FC&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000001</ADDR><REV>001;</REV>
<DESC>HID-совместимое устройство управления</DESC><DEVPATH>\\?\hid#saitekhotkeys#2&2addafed&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>6</DEVINST><INSTANCE>HID\SAITEKHOTKEYS\2&2ADDAFED&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID-совместимый системный контроллер</DESC><DEVPATH>\\?\hid#vid_09da&pid_fa34&mi_02&col02#8&31fea978&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>7</DEVINST><INSTANCE>HID\VID_09DA&PID_FA34&MI_02&COL02\8&31FEA978&0&0001</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000002</ADDR><REV>001;</REV>
<DESC>HID-совместимое устройство управления</DESC><DEVPATH>\\?\hid#vid_09da&pid_fa34&mi_02&col03#8&31fea978&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>8</DEVINST><INSTANCE>HID\VID_09DA&PID_FA34&MI_02&COL03\8&31FEA978&0&0002</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000003</ADDR><REV>001;</REV>
<DESC>HID-совместимое устройство, определенное поставщиком</DESC><DEVPATH>\\?\hid#vid_2e97&pid_1001&mi_02#8&3653416d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>9</DEVINST><INSTANCE>HID\VID_2E97&PID_1001&MI_02\8&3653416D&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000001</ADDR><REV>0019</REV>
<DESC>HID-совместимое устройство, определенное поставщиком</DESC><DEVPATH>\\?\hid#vid_09da&pid_fa34&mi_02&col04#8&31fea978&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>10</DEVINST><INSTANCE>HID\VID_09DA&PID_FA34&MI_02&COL04\8&31FEA978&0&0003</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000004</ADDR><REV>001;</REV>
<DESC>Клавиатура HID</DESC><DEVPATH>\\?\hid#vid_09da&pid_fa34&mi_02&col01#8&31fea978&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>11</DEVINST><INSTANCE>HID\VID_09DA&PID_FA34&MI_02&COL01\8&31FEA978&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000001</ADDR><REV>001;</REV>
<DESC>HID-совместимая мышь</DESC><DEVPATH>\\?\hid#vid_09da&pid_fa34&mi_01#8&1ece8d3a&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>12</DEVINST><INSTANCE>HID\VID_09DA&PID_FA34&MI_01\8&1ECE8D3A&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000001</ADDR><REV>001;</REV>
<DESC>HID-совместимое устройство управления</DESC><DEVPATH>\\?\hid#vid_2e97&pid_1001&mi_00#8&ff308f1&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>13</DEVINST><INSTANCE>HID\VID_2E97&PID_1001&MI_00\8&FF308F1&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000001</ADDR><REV>0019</REV>
<DESC>HID-совместимый системный контроллер</DESC><DEVPATH>\\?\hid#vid_09da&pid_50fd&mi_02&col02#8&a4e2d5f&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>14</DEVINST><INSTANCE>HID\VID_09DA&PID_50FD&MI_02&COL02\8&A4E2D5F&0&0001</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000002</ADDR><REV>00=1</REV>
<DESC>HID-совместимая мышь</DESC><DEVPATH>\\?\hid#vid_09da&pid_50fd&mi_01#8&2211b9a4&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>15</DEVINST><INSTANCE>HID\VID_09DA&PID_50FD&MI_01\8&2211B9A4&0&0000</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000001</ADDR><REV>00=1</REV>
<DESC>Клавиатура HID</DESC><DEVPATH>\\?\hid#saitekkeyboard#2&343dacb3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>16</DEVINST><INSTANCE>HID\SAITEKKEYBOARD\2&343DACB3&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID-совместимое устройство, определенное поставщиком</DESC><DEVPATH>\\?\hid#vid_2e97&pid_1001&mi_01#8&2323252f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>17</DEVINST><INSTANCE>HID\VID_2E97&PID_1001&MI_01\8&2323252F&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR><REV>0019</REV>
<DESC>Клавиатура HID</DESC><DEVPATH>\\?\hid#vid_09da&pid_50fd&mi_02&col01#8&a4e2d5f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>18</DEVINST><INSTANCE>HID\VID_09DA&PID_50FD&MI_02&COL01\8&A4E2D5F&0&0000</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000001</ADDR><REV>00=1</REV>
<DESC>HID-совместимое устройство управления</DESC><DEVPATH>\\?\hid#vid_09da&pid_50fd&mi_02&col03#8&a4e2d5f&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>19</DEVINST><INSTANCE>HID\VID_09DA&PID_50FD&MI_02&COL03\8&A4E2D5F&0&0002</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000003</ADDR><REV>00=1</REV>
<DESC>HID-совместимое устройство, определенное поставщиком</DESC><DEVPATH>\\?\hid#vid_09da&pid_50fd&mi_02&col04#8&a4e2d5f&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>20</DEVINST><INSTANCE>HID\VID_09DA&PID_50FD&MI_02&COL04\8&A4E2D5F&0&0003</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000004</ADDR><REV>00=1</REV>
------[ HID Device Info / HID-совместимое устройство управления ]------
Device ID                 : 06A3-5081
Revision                  : 0001h
Device Instance           : HID\SAITEKHOTKEYS\2&2ADDAFED&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 3
Output Report Byte Length : 0
Feature Report Byte Length: 0
------[ HID Device Info / HID-совместимый системный контроллер ]------
Revision                  : 001Bh
Device Instance           : HID\VID_09DA&PID_FA34&MI_02&COL02\8&31FEA978&0&0001
Usage                     : 0080h
Usage Page                : 0001h
Input Report Byte Length  : 2
Revision                  : 001Bh
Device Instance           : HID\VID_09DA&PID_FA34&MI_02&COL03\8&31FEA978&0&0002
Usage                     : 0001h
Usage Page                : 000Ch
------[ HID Device Info / HID-совместимое устройство, определенное поставщиком ]------
Revision                  : 0019h
Device Instance           : HID\VID_2E97&PID_1001&MI_02\8&3653416D&0&0000
Usage                     : 0001h
Usage Page                : FF00h
Input Report Byte Length  : 16
Revision                  : 001Bh
Device Instance           : HID\VID_09DA&PID_FA34&MI_02&COL04\8&31FEA978&0&0003
Usage                     : 0434h
Usage Page                : FF52h
Input Report Byte Length  : 64
Feature Report Byte Length: 64
Revision                  : 0019h
Device Instance           : HID\VID_2E97&PID_1001&MI_00\8&FF308F1&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 0
Feature Report Byte Length: 65
Revision                  : 00D1h
Device Instance           : HID\VID_09DA&PID_50FD&MI_02&COL02\8&A4E2D5F&0&0001
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0019h
Device Instance           : HID\VID_2E97&PID_1001&MI_01\8&2323252F&0&0000
Usage                     : 0092h
Usage Page                : FF1Ch
Feature Report Byte Length: 264
Revision                  : 00D1h
Device Instance           : HID\VID_09DA&PID_50FD&MI_02&COL03\8&A4E2D5F&0&0002
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 00D1h
Device Instance           : HID\VID_09DA&PID_50FD&MI_02&COL04\8&A4E2D5F&0&0003
Usage                     : 0042h
Usage Page                : FF30h
Feature Report Byte Length: 72
------[ DevClass / COM Ports ]------
<DESC>Последовательный порт (COM1)</DESC><DEVPATH>\\?\acpi#pnp0501#0#{86e0d1e0-8089-11d0-9ce4-08003e301f73}</DEVPATH><DEVINST>32</DEVINST><INSTANCE>ACPI\PNP0501\0</INSTANCE><BUSNUM>00000000</BUSNUM>
<DESC>USB-SERIAL CH340 (COM3)</DESC><DEVPATH>\\?\usb#vid_1a86&pid_7523#6&2f1ce26c&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}</DEVPATH><DEVINST>26</DEVINST><INSTANCE>USB\VID_1A86&PID_7523\6&2F1CE26C&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0262</REV>
------[ DevClass / LPT Ports ]------
<DESC>Порт принтера (LPT1)</DESC><DEVPATH>\\?\acpi#pnp0400#0#{97f76ef0-f883-11d0-af1f-0000f800845c}</DEVPATH><DEVINST>33</DEVINST><INSTANCE>ACPI\PNP0400\0</INSTANCE><BUSNUM>00000000</BUSNUM>
------[ DevClass / Modems ]------
< No Modem Found >
------[ DevClass / SideShow Devices ]------
< No SideShow Device Found >
------[ DevClass / GX3 Devices ]------
< No GX3 Device Found >
------[ DevClass / USBXpress Devices ]------
< No USBXpress Device Found >
------[ DevClass / WinUSB Devices ]------
< No WinUSB Device Found >
------[ LibUsb0 Devices ]------
Device Description        : \\.\libusb0-0001--0x2a55-0x9990
Device Number             : 1
Device Class              : 00 / 00
Product                   : SmatCool
Supported USB Version     : 2.00
------[ CH341 Devices ]------
< No CH341 Device Found >
------[ FTD2xx Devices ]------
< No FTD2xx Device Found >
------[ LibMPSSE Devices ]------
< No LibMPSSE Device Found >
------[ SiUSBXp Devices ]------
SiUSBXp.dll Path =
< No SiUSBXp Device Found >
------[ T-Balancer Devices ]------
< No T-Balancer Device Found >
------[ Koolance TMS-200 Devices ]------
< No T-Koolance TMS-200 Device Found >
------[ GRID+ V3 Devices ]------
< No GRID+ V3 Device Found >
------[ Smart Dev V2 Devices ]------
< No Smart Dev V2 Device Found >
------[ Kraken X-2/X-3 Devices ]------
< No Kraken X-2/X-3 Device Found >
