fixed: CPU Core Voltage wrong (ASRock Z77 OC Formula)
Posted (edited)
I've been testing my CPU voltage with a digital multi meter and compared it's readings to Aida64. Aida64 is reporting a much higher core voltage than the DMM. The DMM reports 1.238v but Aida64 reports 1.281v! I use Aida64 while overclocking so I need it to be accurate or at least closer than what it is now. It's a lot different.
Can this be looked into and resolved?
Thanks.
Update: I ran the test again and now it's showing a more accurate v-core. Must have just been some kind of glitch or something
Edited by tw33k
This continues to happen from time to time now with v3.00.2500. It got so bad I had reinstall Aida to get the correvt CPU voltage to show. Will try the latest BETA and see
Please note that Vcore measurement is done by the onboard sensor chip, so in case you find the measured values slightly inaccurate, it could well be because of the voltage level measurement inaccuracy of the sensor chip :(
BTW, what motherboard do you have?
As you can see in the pic I posted Aida64 reports 1.281v while CPU-Z reports 1.248v which is closer to the actual voltage of 1.238v reported by my DMM. When this occurs I have to repeatedly shut down and restart Aida64 until the voltage is correct which is a real pain and sometimes it just doesn't. When I'm stress testing, which is often, I prefer to just use Aida64 CPUID but I can't always rely on it. The board is an ASRock z77 OC Formula
Please post a screen shot that shows AIDA64 Vcore reading against ASRock Formula Drive.  It should be the definitive reference tool for sensor readings.
With Aida64 the voltage displayed goes as low as 1.141v and as high as 1.206v. This is using a fixed voltage set to 1.190v in the BIOS.
Thank you.  It seems your motherboard has a few tricks up its sleeves :)  The CPU Vcore seems to be influenced by the onboard CHL8326 VRM controller.  Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump.  Copy-paste the full results into this topic.
Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full).  Copy-paste the full results into this topic.
------[ AIDA64 v3.00.2500 ]------
------[ Microsoft Windows 8 Professional 6.2.9200.16581 (64-bit) ]------
Motherboard ID      : 63-0100-000001-00101111-050312-Chipset$AS684211_BIOS DATE: 02/22/13 10:55:00 VER: 04.06.05
Motherboard Model   : ASRock Z77 OC Formula
Motherboard Chipset : Intel Panther Point Z77, Intel Ivy Bridge
DMI MB Manufacturer : ASRock
DMI MB Product      : Z77 OC Formula
DMI MB Version      :
DMI MB Serial       :
DMI SYS Manufacturer: To Be Filled By O.E.M.
DMI SYS Product     : To Be Filled By O.E.M.
DMI SYS Version     : To Be Filled By O.E.M.
DMI SYS Serial      : To Be Filled By O.E.M.
DMI BIOS Version    : P2.20
ITE 87xx Port           = 00h
ITE 87xx Device ID      = 0000h
ITE 87xx Version        = 00h
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0290h
Winbond SuperIO HWMonitor Port/64 = 0000h
Winbond SuperIO Device ID         = C333h
Winbond Sensor ID A3/5C/reg$58    = A3 / 5C / C1
Fintek SuperIO Port           = 00h
Fintek SuperIO Device ID      = 0000h
LPC47 SuperIO Device ID      = FFFFh
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------
0000  04 FF 04 FF  00 FF FF FF  FF FF FF FF  FF FF FF FF
0010  04 FF 00 00  00 00 FF FF  40 00 00 00  00 8F 00 00
0020  A2 E5 CE CE  5D D2 59 13  FF FF FF DA  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0040  03 00 50 FF  FF 00 3F FF  2D FF FF FF  18 05 00 A3
0050  FF FF FF FF  FF FF FF FF  C1 FF FF FF  FF 00 00 FF
0060  A2 FF FF FF  FF 01 00 FF  FF FF FF FF  FF FF FF FF
0070  00 0A 00 13  80 19 80 29  00 FF FF FF  FF FF FF FF
0080  FF 03 1F 0F  FF 3C 3C 3C  00 00 00 00  00 00 00 00
0090  0A 00 00 00  00 0A 0A 0A  0A AA EF 80  FF 40 46 C4
00A0  0E 01 00 00  FF 00 00 FF  00 00 80 66  66 06 01 01
00B0  00 00 00 00  00 00 24 00  1C 00 00 34  28 C0 C4 FF
00C0  01 00 00 00  00 00 00 00  00 0F 01 FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00E0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Reg$20 CPU Core:  r = 162,  r*0.016 = 2.59
Reg$21  CPU Aux:  r = 229,  r*0.016 = 3.66
Reg$22   +3.3 V:  r = 206,  r*0.016 = 3.30
Reg$23     +5 V:  r = 206,  r*0.016 = 3.30
Reg$24    +12 V:  r =  93,  r*0.016 = 1.49
Reg$25    -12 V:  r = 210,  r*0.016 = 3.36
Reg$26     -5 V:  r =  89,  r*0.016 = 1.42
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------
0000  01 00 00 0A  0A 01 01 3C  FF FF FF FF  00 FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  00 19 23 2D  37 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 7F FF FF  00 01 00 00  00 00 00 00
0040  FF FF FF FF  FF A4 00 FF  FF FF FF FF  FF FF 00 FF
0050  13 00 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------
0000  8C 32 02 0A  0A 01 01 3C  FF FF FF FF  00 FF FF FF
0020  00 28 32 3C  46 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0050  29 00 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------
0000  03 00 00 0A  0A 01 01 3C  FF FF FF FF  00 FF FF FF
0030  FF 00 FF FF  00 3C FF FF  00 01 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0020  FF FF FF 96  64 96 64 E1  96 FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  3F 00 03 FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  31 13 FF FF  00 00 00 FF  00 DE 1D B1  09 FF FF FF
0060  FF 01 00 00  00 00 00 00  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------
0000  FF FF 00 00  00 00 FF FF  FF FF FF FF  FF 00 00 FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  D8 00 00 FF  00 00 00 00  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 07 01  01 FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------
0000  00 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF 01 02 03  01 01 01 FF  00 00 00 14  14 14 00 FF
0030  FF 1F FF 1F  FF 1F 12 0A  FF 1F 00 00  00 00 00 00
0040  00 00 00 00  02 02 02 FF  FF FF FF FF  FF FF 00 FF
0050  7F 7F 7F 7F  7F 7F 00 A4  00 A4 00 A4  08 FF 00 A4
0070  7F 7F 50 4B  04 7F 7F 50  4B 04 7F 7F  50 4B 04 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------
0000  FF 95 02 10  00 00 00 00  00 69 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 EC  ED F8 80 F8  80 F8 80 01
0020  1C 02 06 00  00 00 EF 20  00 EF 00 00  00 00 00 00
0030  00 00 00 FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
   0027  0150  0250  007D  007E  062B  062C  062D  071C  0720
T:   20    19    41   255   255    20    20    20   128    29
T:   19    19    41   255   255    19    19    19   128    28
T:   19    19    41   255   255    19    19    19   128    25
T:   19    19    41   255   255    19    19    19   128    22
T:   20    19    41   255   255    20    20    20   128    22
T:   20    19    41   255   255    20    20    20   128    21
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
DMI MB Version      :
DMI MB Serial       :
ITE 87xx Port           = 00h
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
DMI MB Version      :
DMI MB Serial       :
------[ GPIO @ isa 0500 ]------
0000  FF F1 03 B9  FF 3E BF 8E  00 00 00 00  AF 7F E3 68
0010  00 00 00 00  00 00 00 00  00 00 04 00  00 00 00 00
0020  00 00 08 00  00 00 00 00  00 00 00 00  00 30 00 00
0030  07 00 02 02  34 FF 56 1F  87 0F FF FC  00 00 00 00
------[ SMBus #0 ]------
SMBus Type  : Intel ICH
SMBus Port  : F040
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B00-D29 ]------
  0000  1E A6 76 1D DD 5B F7 30 10 01 09 FF FF 97 97 00  ..v..[.0........
  0010  05 08 46 87 80 00 00 00 00 FF 50 C4 A4 00 E8 A1  ..F.......P.....
  0020  26 4B E0 A1 22 28 00 00 8D 99 14 17 17 00 A6 22  &K.."(........."
  0030  44 33 55 00 A8 B9 B9 D2 73 2D 10 80 00 51 00 54  D3U.....s-...Q.T
  0040  AE 29 00 02 41 41 3B 3B 3B 3B 3B 3B F1 C1 C2 82  .)..AA;;;;;;....
  0050  D9 82 D9 82 D9 A0 02 9F D8 05 D0 9B BA E4 B8 58  ...............X
  0060  F0 05 F0 18 1B 00 00 00 00 00 00 23 91 03 00 02  ...........#....
  0070  00 00 00 03 55 22 05 00 00 00 B0 15 00 00 00 D1  ....U"..........
  0080  E3 00 D0 A9 DB 04 D0 F0 B8 FF BB 4E 0D 00 03 FE  ...........N....
  0090  00 07 C0 11 98 00 00 88 00 00 16 14 1F AD 50 00  ..............P.
  00A0  00 00 00 00 00 00 00 00 00 03 00 00 03 FB 9F 00  ................
  00B0  00 00 0F 00 00 00 01 FF FF 88 88 01 0A 0A FF 88  ................
  00C0  01 01 01 00 00 C0 00 00 00 00 00 00 00 00 00 80  ................
  00D0  60 D5 00 00 80 30 00 00 08 00 01 00 00 00 00 00  `....0..........
  00E0  00 00 00 15 15 00 00 00 01 00 00 00 00 01 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  1E1E A6A6 7676 1D1D DDDD 5B5B F7F7 3030 1010 0101 0909 FFFF FFFF 9797 9797 0000
  0010  0505 0808 4646 8787 8080 0000 0000 0000 0000 FFFF 5050 C4C4 A4A4 0000 E8E8 A1A1
  0020  2626 4B4B E0E0 A1A1 2222 2828 0000 0000 8D8D 9999 1414 1717 1717 0000 A6A6 2222
  0030  4444 3333 5555 0000 A8A8 B9B9 B9B9 D2D2 7373 2D2D 1010 8080 0000 5151 0000 5454
  0040  AEAE 0000 0000 0202 4141 4141 3B3B 3D3D 3D3D 3B3B 3B3B 3A3A F1F1 C1C1 C2C2 8282
  0050  D9D9 8282 D9D9 8282 D9D9 A0A0 0202 A6A6 D8D8 0000 D0D0 9B9B BABA 0C0C B8B8 5A5A
  0060  F0F0 0101 F0F0 1818 1B1B 0000 0000 0000 0000 0000 0000 2323 9191 0000 0000 0202
  0070  0000 0000 0000 0303 5555 A2A2 0505 0000 0000 0000 B0B0 1616 0000 0000 0000 DDDD
  0080  E3E3 0000 D0D0 9595 DBDB 0000 D0D0 EDED B8B8 FFFF BBBB 4E4E 0D0D 0000 0303 0000
  0090  FFFF 0707 C0C0 1111 9898 0000 0000 8888 0000 0000 1616 1414 1F1F ADAD 5050 0000
  00A0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0303 0000 0000 0303 FBFB 9F9F 0000
  00B0  0000 0000 0F0F 0000 0000 0000 0101 FFFF FFFF 8888 8888 0101 0A0A 0A0A FFFF 8888
  00C0  0101 0101 0101 0000 0000 C0C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 8080
  00D0  6060 D5D5 0000 0000 8080 3030 0000 0000 0808 0000 0101 0000 0000 0000 0000 0000
  00E0  0000 0000 0000 1515 1515 0000 0000 0000 0101 0000 0000 0000 0000 0101 0000 0000
  00F0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D2D ]------
  0000  31 43 FF FF FF FF FF FF 00 01 00 FF 5A 50 C5 51  1C..........ZP.Q
  0010  FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF  ................
  0020  FF FF 03 01 0F 00 0F 0F 0F FF 02 0A 00 02 00 00  ................
  0030  00 00 00 A0 00 00 68 2A EF 50 00 44 00 DB 0B 73  ......h*.P.D...s
  0040  47 00 46 05 46 07 45 02 46 00 47 02 47 02 40 01  G.F.F.E.F.G.G.@.
  0050  3B 01 44 03 46 03 45 03 3F 05 45 02 44 01 43 02  ;.D.F.E.?.E.D.C.
  0060  47 04 17 05 00 00 00 00 00 00 FF FF FF FF FF FF  G...............
  0070  14 FF FF FF FF FF FF FF FF FF 50 C5 51 FF FF FF  ..........P.Q...
  0080  FF 1F FF 1F FF 1F 09 08 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00  ................
  00C0  10 FF FF 1D 00 57 00 00 00 00 40 FF FF 1F 01 FF  .....W....@.....
  00D0  0F 0F 0F 0F 4F FF 00 00 00 00 00 00 00 00 00 00  ....O...........
  00E0  00 00 00 00 00 00 FF FF 67 7F 00 07 0C 0B 04 04  ........g......
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00  ................
  0000  FF31 FF43 FFFF FFFF FFFF FFFF FFFF FFFF FF00 FF01 FF00 FFFF FF5A FF50 FFC5 FF51
  0010  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF
  0020  FFFF FFFF FF03 FF01 FF0F FF00 FF0F FF0F FF0F FFFF FF02 FF0A FF00 FF02 FF00 FF00
  0030  FF00 FF00 FF00 FFA0 FF00 FF00 FF68 FF2A FFEF FF50 FF00 FF44 FF00 FFDB FF0B FF73
  0040  FF47 FF00 FF46 FF05 FF46 FF07 FF45 FF02 FF46 FF00 FF47 FF02 FF47 FF02 FF40 FF01
  0050  FF3B FF01 FF44 FF03 FF46 FF02 FF45 FF03 FF3F FF05 FF45 FF02 FF44 FF01 FF43 FF02
  0060  FF47 FF04 FF17 FF05 FF00 FF00 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FF14 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF50 FFC5 FF51 FFFF FFFF FFFF
  0080  FFFF FF1F FFFF FF1F FFFF FF1F FF09 FF08 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0090  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00B0  FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF10 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF40 FFFF FFFF FF1F FF01 FFFF
  00D0  FF0F FF0F FF0F FF0F FF4F FFFF FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF00 FF00 FF00 FF00 FF00 FF00 FFFF FFFF FF67 FF7F FF00 FF07 FF0C FF0B FF04 FF04
  00F0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FFFF FF00
------[ SMBus Device B00-D41 ]------
  0000  FF 88 FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0010  FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF  ................
  0020  15 FF FF FF FF 00 00 FF FF FF FF FF FF FF FF FF  ................
  0030  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0040  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0050  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0070  FF FF FF FF FF FF FF FF 02 02 FF FF FF 00 80 FF  ................
  0080  00 FF FF FF FF FF FF FF 82 A8 FF 6B 5B 18 1B FF  ...........k[...
  0090  FF FF FF FF FF FF A9 E9 12 FF 01 01 FF FF FF FF  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00D0  39 FF FF FF 00 FF 80 EE 00 00 00 01 FF FF FF FF  9...............
  00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  FFFF 4E88 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0010  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 15B0 FFFF FFFF FFFF FFFF FFFF FFFF
  0020  BC15 FFFF FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0030  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0040  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0050  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0060  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF AC02 0002 FFFF FFFF FFFF 6200 5680 FFFF
  0080  9F00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF D982 D8A7 FFFF 0A6C F059 0018 001A FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF DBA9 E3DD 1212 FFFF 0D01 0701 FFFF FFFF FFFF FFFF
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00D0  FF39 FFFF FFFF FFFF 1000 FFFF 4F80 B8ED 0000 8100 3C00 5001 FFFF FFFF FFFF FFFF
  00E0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00F0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D42 ]------
  0080  00 FF FF FF FF FF FF FF 82 00 FF 0A 00 1B 18 FF  ................
  0090  FF FF FF FF FF FF 03 00 12 FF 01 01 FF FF FF FF  ................
  00D0  0F FF FF FF 00 FF 80 FF 00 00 00 01 FF FF FF FF  ................
  0000  FFFF 4488 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0010  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 1FB0 FFFF FFFF FFFF FFFF FFFF FFFF
  0020  B615 FFFF FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF A602 0002 FFFF FFFF FFFF 6800 5C80 FFFF
  0080  9500 FFFF FFFF FFFF FFFF FFFF FFFF FFFF D982 D000 FFFF 000A F001 001A 0018 FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF D000 D000 1812 FFFF 0D01 0701 FFFF FFFF FFFF FFFF
  00D0  FF0F FFFF FFFF FFFF 1A00 FFFF 4580 BBFF 0000 8B00 3600 5A01 FFFF FFFF FFFF FFFF
  0000  00 00 00 04 00 00 00 00 00 27 59 04 03 03 07 13  .........'Y.....
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF27 FF59 FF04 FF03 FF03 FF07 FF13
  0010  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0030  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0040  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0050  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0060  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0070  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0080  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0090  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00B0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00D0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00F0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
------[ SMBus Device B00-D50 ]------
  0000  92 11 0B 02 04 21 00 09 03 11 01 08 0C 00 7E 00  .....!........~.
  0010  69 78 69 30 69 11 20 89 20 08 3C 3C 00 F0 83 05  ixi0i. . .<<....
  0030  00 00 00 00 00 00 00 00 00 00 00 00 0F 11 21 01  ..............!.
  0070  00 00 00 00 00 04 CD 00 00 00 00 00 00 00 A9 E1  ................
  0080  46 33 2D 32 34 30 30 43 31 30 2D 38 47 54 58 00  F3-2400C10-8GTX.
  0090  00 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00  ................
  00B0  0C 4A 3F 13 01 08 0A 60 11 2D 07 3F 40 00 2E 4C  .J?....`.-.?@..L
  00C0  4C 6A 10 CB 1B 3F 00 20 08 3C 28 00 A8 3C 00 00  Lj...?. .<(..<..
  00D0  10 00 25 D6 AF 87 87 BB 00 00 00 00 2D 08 4D 40  ..%.........-.M@
  00E0  00 38 5D 5D 80 10 F5 55 4B 00 C4 09 48 30 00 C9  .8]]...UK...H0..
  00F0  48 00 00 10 00 25 00 00 00 00 00 00 00 00 00 00  H....%..........
------[ SMBus Device B00-D52 ]------
------[ Chips Found ]------
B00-D2D: Nuvoton NCT7904D
B00-D52: SPD
We've implemented support for the onboard CHL8328 VRM chip of your motherboard.  Please upgrade to the latest beta version of AIDA64 Extreme Edition available at:
http://www.aida64.com/downloads/aida64extremebuild2536f5mtnpwq1lzip
With this beta you'll see new items on the Sensor page.  The most important one would be the CPU VRM voltage, which hopefully would indicate the right Vcore voltage you're looking for.
Let me know how it works.
Great. Will try it tonight and let you know. Thanks so much for all the work you do.
UPDATE: Ran a quick test and it all looks good so far. I love the new extras you put into it. Thanks again.
