Agrias Posted December 26, 2023 Posted December 26, 2023 On the latest beta version 7.00.6711 and I can't get the correct fans to show up. CPU fan is actually my AIO pump (running at 5500 RPM, no way to mistaken that for a fan). Chasis fan shows up, but those are actually my case fans. What happened to CPU fan? I've attached the isasensordump.txt. Thank you in advance! isasensordump.txt 1 Quote
halimt Posted December 26, 2023 Posted December 26, 2023 Same here - CPU fan is lost for me as well Quote
Fiery Posted December 26, 2023 Posted December 26, 2023 12 hours ago, Agrias said: On the latest beta version 7.00.6711 and I can't get the correct fans to show up. CPU fan is actually my AIO pump (running at 5500 RPM, no way to mistaken that for a fan). Chasis fan shows up, but those are actually my case fans. What happened to CPU fan? I've attached the isasensordump.txt. Thank you in advance! Thank you, we'll fix the issue in the next AIDA64 beta update. Quote
Fiery Posted December 26, 2023 Posted December 26, 2023 11 hours ago, halimt said: Same here - CPU fan is lost for me as well Do you have the same motherboard, X670E Steel Legend? Quote
Agrias Posted December 26, 2023 Author Posted December 26, 2023 11 minutes ago, Fiery said: Thank you, we'll fix the issue in the next AIDA64 beta update. Thank you, looking forward to it! Quote
Fiery Posted January 3, 2024 Posted January 3, 2024 On 12/26/2023 at 2:09 PM, Agrias said: Thank you, looking forward to it! The above mentioned new AIDA64 beta update is available for download now at: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. 1 Quote
Agrias Posted January 5, 2024 Author Posted January 5, 2024 On 1/4/2024 at 12:16 AM, Fiery said: The above mentioned new AIDA64 beta update is available for download now at: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. Just tested it out and now my CPU fan shows (it worked!), thank you! Quote
Fiery Posted January 5, 2024 Posted January 5, 2024 1 hour ago, Agrias said: Just tested it out and now my CPU fan shows (it worked!), thank you! Thank you for your feedback! Quote
