fffrankw Posted January 9, 2024 Posted January 9, 2024 I'm using AX206 LCD rotated 90 degrees, it works fine till the PC goes to sleep mode. After wake up, the display goes back to horizontal mode, losing the bottom half of the screen. The layout remains as original vertical. It can be fixed by manually by re-do the 90 rotation in LCD preference. I have updated to the latest v7.0, this problem remains. Does any one know a permanent fix to this? Quote
Fiery Posted January 10, 2024 Posted January 10, 2024 9 hours ago, fffrankw said: I'm using AX206 LCD rotated 90 degrees, it works fine till the PC goes to sleep mode. After wake up, the display goes back to horizontal mode, losing the bottom half of the screen. The layout remains as original vertical. It can be fixed by manually by re-do the 90 rotation in LCD preference. I have updated to the latest v7.0, this problem remains. Does any one know a permanent fix to this? We will fix it in the next AIDA64 beta update. I'll post a message into this topic once the new beta build becomes available for download. 1 Quote
Fiery Posted January 17, 2024 Posted January 17, 2024 On 1/10/2024 at 12:33 AM, fffrankw said: I'm using AX206 LCD rotated 90 degrees, it works fine till the PC goes to sleep mode. After wake up, the display goes back to horizontal mode, losing the bottom half of the screen. The layout remains as original vertical. It can be fixed by manually by re-do the 90 rotation in LCD preference. I have updated to the latest v7.0, this problem remains. Does any one know a permanent fix to this? The above mentioned new AIDA64 beta build is now available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. 1 Quote
