Sensor Icons has problems (HP 6535b Notebook)
Such temperature readings are usually read from the onboard sensor chip, but not from the usual CPU or Motherboard registers. So they could either mean a special temperature (e.g. PWM temperature, chipset temperature, DIMM temperature), or an invalid reading. You can check out the Computer / Sensor page to see if those 2 special readings are valid or not.
The sensor is same as "#1 & #2 temperate".
I tried aida64 V1.2. It shows correct as "moterboard & CPU temperate". My computer is HP 6535b notebook.
1) Please copy-paste the full content of the Computer / Sensor page of AIDA64 v1.50 into this topic.
2) Then right-click on the bottom status bar of AIDA64 v1.50 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic.
3) Also right-click on the bottom status bar of AIDA64 v1.50 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic.
Based on that data we can check what happened to the temperature labels.
1)
Field Value
Sensor Properties
Sensor Type SMSC EMC1072/1402/1412 (SMBus 4Ch)
Temperatures
CPU #1 / Core #1 62 癈 (144 癋)
CPU #1 / Core #2 62 癈 (144 癋)
Temperature #1 44 癈 (111 癋)
Temperature #2 55 癈 (131 癋)
TOSHIBA MK3252GSX [ TRIAL VERSION ]
Voltage Values
CPU Core 1.100 V
2)
------[ AIDA64 v1.50.1200 ]------
------[ Microsoft Windows 7 Ultimate 6.1.7600 (32-bit) ]------
Motherboard ID : <DMI>
Motherboard Model : Hewlett-Packard HP Compaq 6535b
Motherboard Chipset : AMD M780, AMD K11
DMI MB Manufacturer : Hewlett-Packard
DMI MB Product : 30E3
DMI MB Version : KBC Version 96.26
DMI MB Serial : CNU9026GVS
DMI SYS Manufacturer: Hewlett-Packard
DMI SYS Product : HP Compaq 6535b
DMI SYS Version : F.15
DMI SYS Serial : CNU9026GVS
DMI BIOS Version : 68GTT Ver. F.15
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 00h
Winbond SuperIO HWMonitor Port = 0000h
Winbond SuperIO Device ID = FFFFh
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = 4501h
------[ SB7xx/8xx PM2 at 0CD0 ]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0020 00 00 00 00 00 00 00 00 FF FF FF 00 00 00 00 00
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0040 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0070 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 51 F0 F8 F1 F0 F4 F0 70 00 EC FD FD C0 F0 F0 F0
00F0 B0 00 F0 00 80 00 00 20 E2 F0 10 FF FF FF FF FF
Reg$59VIN0: r = $0000, r*0.000046 = 0.0000
Reg$5DVIN1: r = $0000, r*0.000046 = 0.0000
Reg$61VIN2: r = $0000, r*0.000046 = 0.0000
Reg$65VIN3: r = $0000, r*0.000046 = 0.0000
Reg$69VIN4: r = $0000, r*0.000046 = 0.0000
Reg$6DVIN5: r = $0000, r*0.000046 = 0.0000
Reg$71VIN6: r = $0000, r*0.000046 = 0.0000
Reg$75VIN7: r = $0000, r*0.000046 = 0.0000
------[ SB7xx/8xx PM at 0CD6 ]------
0000 00 00 00 00 80 00 00 00 00 00 02 00 00 4B 0D 00
0010 3B 00 00 00 00 00 00 00 00 00 92 00 10 00 00 00
0020 00 04 04 04 08 04 10 04 20 04 B0 00 00 08 B8 00
0030 44 10 00 00 00 00 08 06 00 00 00 00 00 00 01 FF
0040 00 00 50 9E 04 00 00 00 00 00 00 00 00 00 00 00
0050 E0 05 88 C1 00 07 00 05 0C 08 00 00 00 00 00 07
0060 A0 08 00 05 02 30 20 06 1C 01 00 00 F0 00 C0 FE
0070 00 00 0B 80 40 C5 FF FF FF FB 00 00 1F 02 00 00
0080 06 21 43 55 1A 02 00 00 10 10 90 01 00 11 00 20
0090 00 FF 77 00 19 06 00 00 00 00 B6 00 00 00 D0 00
00A0 00 00 00 00 00 00 00 00 00 00 00 00 11 00 D0 FE
00B0 6B 50 91 00 00 00 00 00 00 00 00 00 00 00 00 00
00C0 00 01 00 AA 55 55 55 00 00 01 7E 00 00 00 00 00
00D0 01 00 00 00 80 00 00 C0 00 00 00 00 00 00 00 00
00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
3)
------[ SMBus #0 ]------
SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port : 0B00
Can Have SPD: Yes
Scan Type : Full
------[ SMBus Device B00-D1D ]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3B ...............;
0010 05 9C 02 00 11 00 05 80 17 DF 02 10 00 00 00 00 ................
0020 47 0A 01 00 00 00 00 FF 00 03 00 FC 00 33 00 00 G............3..
0030 95 25 14 02 2A 15 11 01 00 00 00 00 00 00 00 00 .%..*...........
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3B ...............;
0090 05 9C 02 00 11 00 05 80 17 DF 02 10 00 00 00 00 ................
00A0 47 0A 01 00 00 00 00 FF 00 04 00 FB 00 33 00 00 G............3..
00B0 95 25 14 02 2A 15 11 01 00 00 00 00 00 00 00 00 .%..*...........
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 3B3B
0010 0505 9C9C 0202 0000 1111 0000 0505 8080 1717 DFDF 0202 1010 0000 0000 0000 0000
0020 4747 0A0A 0101 0000 0000 0000 0000 FFFF 0000 0303 0000 FBFB 0000 3232 0000 0000
0030 9595 2525 1414 0202 2A2A 1515 1111 0101 0000 0000 0000 0000 0000 0000 0000 0000
0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 3B00 053B
0090 9C05 029C 0002 1100 0011 0500 8005 1780 DF17 02DF 1002 0010 0000 0000 0000 4700
00A0 0A47 010A 0001 0000 0000 0000 FF00 00FF 0400 0004 FB00 00FB 3300 0033 0000 9500
00B0 2595 1425 0214 2A02 152A 1115 0111 0001 0000 0000 0000 0000 0000 0000 0000 0000
00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D4C ]------
0000 2C 36 80 20 06 45 00 5C 00 20 06 45 00 5C 00 00 ,6. .E.\. .E.\..
0010 60 00 00 00 00 00 00 00 00 6A 00 00 00 00 00 00 `........j......
0020 55 0A 70 00 00 0C 00 12 00 60 00 00 00 00 00 00 U.p......`......
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 06 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 6C 40 00 00 00 00 00 00 26 12 06 50 ....l@......&..P
00B0 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ..............
00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 20 5D 01 ............. ].
0000 FF2C FF36 FF80 FF20 FF06 FF45 FF00 FF5C FF00 FF20 FF06 FF45 FF00 FF5C FF00 FF00
0010 FF60 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF6A FF00 FF00 FF00 FF00 FF00 FF00
0020 FF55 FF0A FF70 FF00 FF00 FF0C FF00 FF12 FF00 FF40 FF00 FF00 FF00 FF00 FF00 FF00
0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0060 FF06 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0070 FF06 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00A0 FF00 FF00 FF00 FF00 FF6C FF40 FF00 FF00 FF00 FF00 FF00 FF00 FF26 FF12 FF06 FF50
00B0 FF20 FF20 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF20 FF5D FF01
------[ Chips Found ]------
B00-D4C: SMSC EMC1072/1402/1412
