landor Posted June 4, 2013 Posted June 4, 2013 I miss a feature from the tray and sensor panel: the battery charging percentage value in % Thanks Quote
Fiery Posted June 6, 2013 Posted June 6, 2013 Battery Charge Rate is already amongst the available SensorPanel items, in the Powers group. Regards, Fiery Quote
landor Posted June 20, 2013 Author Posted June 20, 2013 On 6/6/2013 at 7:34 PM, Fiery said: Battery Charge Rate is already amongst the available SensorPanel items, in the Powers group. Regards, Fiery I can set up only the voltage; http://snag.gy/hBfuf.jpg Quote
Fiery Posted June 25, 2013 Posted June 25, 2013 1) Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> Battery Dump. Copy-paste the full results into this topic. 2) Then go to the Computer / Sensor page of AIDA64, and copy-paste the full page into this topic, using either the right-click menu on the Sensor page, or post a screen shot of the page. Make sure to have the battery charging (so connected to A/C power, and the battery being not fully charged) when you make those tests. Thanks, Fiery Quote
landor Posted June 26, 2013 Author Posted June 26, 2013 On 6/25/2013 at 10:40 AM, Fiery said: 1) Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> Battery Dump. Copy-paste the full results into this topic. 2) Then go to the Computer / Sensor page of AIDA64, and copy-paste the full page into this topic, using either the right-click menu on the Sensor page, or post a screen shot of the page. Make sure to have the battery charging (so connected to A/C power, and the battery being not fully charged) when you make those tests. Thanks, Fiery http://pastebin.com/ZQayvn73 http://snag.gy/88Vn5.jpg http://snag.gy/rQQp4.jpg Quote
Fiery Posted July 22, 2013 Posted July 22, 2013 Thank you for the data. The battery charge rate information should work properly on your system. But please note that it cannot be placed on the Sensor Icons, but only on the rest of the hardware monitoring modules, like OSD Panel or SensorPanel. Quote
