Sensor Panel Righ Click do not work
I can't edit my sensor panel; I can see it change color, but nothing else.
Even though I see the text saying, "Right click to Eddit," nothing happens.
I try to plug and plug the second screen, try only with the main screen on, try with a wired mouse.
Aida64 Extreme v7.00.6700
Any suggestions?
  • Solution
Any suggestions?
You've disabled the right-click menu by disabling the option called "Enable context menu" in AIDA64 / Preferences / Hardware Monitoring / SensorPanel.
