Ryakatsuki Posted March 2, 2024 Posted March 2, 2024 Hi there, I just bought this external monitor but I have no idea how to set this up. Can anyone help me out? 8.8in Computer Temp Monitor, PC Sensor Panel IPS Display voor AIDA64 USB C CPU GPU SSD Data Temperatuur Monitor voor Raspberry Pi voor Linux, voor Windows (Zwart) : Amazon.nl: Elektronica This is the monitor, I'm trying to use a template skin for Aida 64 but I don't know how to get the display to work... Thanks in advance! Quote
rinaldop Posted March 2, 2024 Posted March 2, 2024 1 hour ago, Ryakatsuki said: Hi there, I just bought this external monitor but I have no idea how to set this up. Can anyone help me out? 8.8in Computer Temp Monitor, PC Sensor Panel IPS Display voor AIDA64 USB C CPU GPU SSD Data Temperatuur Monitor voor Raspberry Pi voor Linux, voor Windows (Zwart) : Amazon.nl: Elektronica This is the monitor, I'm trying to use a template skin for Aida 64 but I don't know how to get the display to work... Thanks in advance! In settings select sensor panel and you will see this window. Click 'show sensor panel' then input your resolution and click apply. You should see a sample template appear. Right click on it and select sensor panel manager and this window should appear Click on import and load your template. Quote
Ryakatsuki Posted March 3, 2024 Author Posted March 3, 2024 Thanks for the reply! How do I get it to show on the monitor? I havent gotten a template yet because im not sure the monitor works. I just cant get the panel to show on the external monitor. Quote
rinaldop Posted March 3, 2024 Posted March 3, 2024 You need to set up your second monitor in Windows display settings and then drag the template window over to the second monitor. Watch this, it will start at the place that tells you what to do Quote
Ryakatsuki Posted March 4, 2024 Author Posted March 4, 2024 It didnt work because the monitor was defective. Got a new one and it works like a charm. Thanks for the help! Any suggestions where to get a skin for 1920x720? Quote
