Two updates ago I enabled remote sensor to view  sensor items from my Android phone while connected to my local wifi network.  It worked fine after a brief configuration.  What I am noticing is after every AIDA64 update the http sensor page stops loading from my Android phone.  To get it to work again I have to change the http port from the original 80 to 8080 or 8080 back to 80.  Unless I do this, the http page will not load after every update gets installed.  I have not tried a reboot after update, but a port change after update gets it working again.
Is there perhaps another way to get remote sensor working again that I am unaware of?  I have had two updates so far, and remote sensor stopped wortking both updates.  Switching the http port as I mentioned resolved the issue.
I suppose it's because when AIDA64 is restarted during the automatic update process, the RemoteSensor module may not be properly closed and de-initialized.  We will tweak that in the next AIDA64 beta update.
