shaunrahim49 Posted March 21, 2024 Posted March 21, 2024 So some reason I keep getting stuck on “detecting sensor operations” the only way for it to work is to disable “low-level sensor operations” but after doing so I can’t get temperature related stats. Quote
Fiery Posted March 21, 2024 Posted March 21, 2024 10 hours ago, shaunrahim49 said: So some reason I keep getting stuck on “detecting sensor operations” the only way for it to work is to disable “low-level sensor operations” but after doing so I can’t get temperature related stats. What motherboard and CPU do you have? If you have any USB devices connected (that aren't a keyboard or mouse), try to disconnect them and check if it makes a difference. Quote
