Tony Lou Posted May 3, 2024 Posted May 3, 2024 I so Hope it was ok to send a message The problem I am having is my fans for the CPU sensor are not detected in Motherboard "MSI MPG X670E CARBON WIFI where CPU fan is not mentioned or shown in the cooling fans and fan speeds section so I went to https:forums.aida64.com/forum/9-hardware-monitoringl I click on "start new Topic" my version of AIDA64 is v7.20,6802 I Also see my ISA sensor Dump on the 20/04/2024 and you get back to me saying thank you! Everything seems to be fine there, I suppose your CPU fan was not shown in the list of the available sensor items because the CPU fan wasn't spinning at the time. so I send a new message back to you because a few people on here was saying Even if the CPU fan wasn't spinning, it should be shown in the list as the same way as the GPU fans are shown even they remain at 0 RPM. I think the problem is somewhere else and it has not solve the issue so can you HELP Many Thank Tony Lou Quote
Loyd Posted May 15, 2024 Posted May 15, 2024 does the fan show up in the bios? and don't ask how as that is so depended on motherboards read your manual  Quote
