Stephanie Posted May 18, 2024 Posted May 18, 2024 pch temperature on msi mpg carbon wifi is 176 -190F. Is this normal? if not, how do i correct it? BTW, cpu temp is 100F. Case is clear and airflow excellent. Quote
Fiery Posted May 19, 2024 Posted May 19, 2024 18 hours ago, Stephanie said: pch temperature on msi mpg carbon wifi is 176 -190F. Is this normal? if not, how do i correct it? BTW, cpu temp is 100F. Case is clear and airflow excellent. In AIDA64 please press Ctrl+Alt+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Stephanie Posted May 19, 2024 Author Posted May 19, 2024 Fiery, thank you for your reply and suggestion.. I found the problem. I had a 3Ware 9690SA 8i raid controlley card in the bottom Pci slot. I removed it and PCH temps are 160-168F Quote
