k3mist Posted May 22, 2024 Posted May 22, 2024 Works in other monitoring software for the MSI MEG Ai1300P Also power supply efficiency is unavailable Quote
k3mist Posted May 22, 2024 Author Posted May 22, 2024 i noticed the psu power package/wattage is not the actual draw from the wall but the internal power draw. im guessing thats also why there is no efficiency? im not sure if efficiency is an actual metric published by the psu or not but it is available in other monitoring utils. internal / wall = efficiency regardless, the psu fan rpm is def not working 😠Quote
Fiery Posted June 19, 2025 Posted June 19, 2025 On 5/23/2024 at 12:51 AM, k3mist said: i noticed the psu power package/wattage is not the actual draw from the wall but the internal power draw. im guessing thats also why there is no efficiency? im not sure if efficiency is an actual metric published by the psu or not but it is available in other monitoring utils. internal / wall = efficiency regardless, the psu fan rpm is def not working 😠Efficiency is an estimated value, it cannot be measured I'm afraid Quote
Fiery Posted June 19, 2025 Posted June 19, 2025 On 5/22/2024 at 11:31 PM, k3mist said: Works in other monitoring software for the MSI MEG Ai1300P Also power supply efficiency is unavailable We've fixed the fan RPM issue in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. 1 Quote
