dEr nECrO Posted June 2, 2024 Posted June 2, 2024 Hi Folks, I looked for this topic in the forums and only found posts related to the Corsair Commander. I have an LCD w/ Aida64 setup and running. I just purchased a new Motherboard and CPU. The new MB, a Gigabyte 670-E, has two 2 pin temp sensors. I’d like to add a temp sensor to my loop, but wasn’t sure if Aida64 could read and display the results. Thanks in advance for any help. Quote
Fiery Posted June 17, 2024 Posted June 17, 2024 On 6/2/2024 at 12:51 PM, dEr nECrO said: Hi Folks, I looked for this topic in the forums and only found posts related to the Corsair Commander. I have an LCD w/ Aida64 setup and running. I just purchased a new Motherboard and CPU. The new MB, a Gigabyte 670-E, has two 2 pin temp sensors. I’d like to add a temp sensor to my loop, but wasn’t sure if Aida64 could read and display the results. Thanks in advance for any help. Expand Yes, those temperature sensors should be measured by AIDA64 properly. Let me know if you cannot see them on the Computer / Sensor page of AIDA64. Quote
