Hello,
AIDA64 (I'm running version 3.00.2594 Beta under Windows 8 64-bit) does not show the CPU fan speed readings on my new Lenovo IdeaPad U430.
Please advise. Thank you.
1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump.  Copy-paste the full results into this topic.
2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full).  Copy-paste the full results into this topic.
3) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump.  Copy-paste the full results into this topic.
ISA Sensor Dump
------[ AIDA64 v3.00.2594 Beta ]------
------[ Microsoft Windows 8 6.2.9200.16628 (64-bit) ]------
Motherboard ID      : <DMI>
Motherboard Model   : Lenovo IdeaPad U430 Touch
Motherboard Chipset : Intel Lynx Point-LP, Intel Haswell
DMI MB Manufacturer : LENOVO
DMI MB Product      : Cherry 4A Touch
DMI MB Version      : 31900003WIN8 STD MLT
DMI MB Serial       : QB07181093
DMI SYS Manufacturer: LENOVO
DMI SYS Product     : 20270
DMI SYS Version     : IdeaPad U430 Touch
DMI SYS Serial      : QTF0NA33100834
DMI BIOS Version    :
ITE 87xx Port           = 00h
ITE 87xx Device ID      = 0000h
ITE 87xx Version        = 00h
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0000h
Winbond SuperIO HWMonitor Port/64 = 0000h
Winbond SuperIO Device ID         = 8587h
Fintek SuperIO Device ID      = 0000h
LPC47 SuperIO Device ID      = 8587h
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             : <TYPE>0</TYPE><LEN>4</LEN><DATA>3112</DATA>
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
SMBus Dump (Full)
DMI BIOS Version    :
------[ GPIO @ isa 0800 ]------
0000  FF FB FF FF  FB FF FF FF  FF FF FF 7F  00 00 00 00
0010  FF FF 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 08 00  00 00 00 00  00 00 00 00  00 00 00 00
0030  00 00 00 00  04 00 00 00  00 00 00 00  00 00 00 00
------[ SMBus #0 ]------
SMBus Type  : Intel ICH
SMBus Port  : 5040
Can Have SPD: Yes
Scan Type   : Full
DMI BIOS Version    :
------[ Embedded Controller at 0066/0062 via Port I/O / Bank #0 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
0010  00 01 00 00  00 00 00 00  00 00 01 01  14 50 05 0C  .............P..
0020  03 41 90 10  08 C0 00 32  00 00 00 00  00 00 22 00  .A.....2......".
0030  00 00 00 00  00 00 00 FF  00 00 00 00  00 00 00 00  ................
0040  EA 03 24 75  61 00 1E 1B  00 11 00 00  00 00 00 00  ..$ua...........
0050  00 00 00 00  04 04 00 00  27 00 00 00  01 01 1C 30  ........'......0
0060  00 80 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
0070  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
0080  00 00 00 00  00 14 01 11  00 00 00 00  00 32 00 07  .............2..
0090  80 00 FF FF  FF FF 00 00  00 00 00 28  00 00 00 00  ...........(....
00A0  53 4D 50 00  31 31 00 00  00 00 00 00  00 00 00 00  SMP.11..........
00B0  00 00 00 00  00 00 00 0F  13 30 00 1B  2D 02 03 BD  .........0..-...
00C0  C2 31 FD 6A  09 69 1D 00  00 00 00 00  00 00 00 00  .1.j.i..........
00D0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
00E0  FE 12 00 00  00 00 00 00  00 80 00 00  00 20 01 80  ............. ..
00F0  03 00 00 02  00 00 20 00  00 0F 02 00  00 00 02 00  ...... .........
Time #1 = 2094
Time #2 = 0
Thank you for the data.  I'm afraid your tablet doesn't implement a sensor solution that would be compatible with existing AIDA64 sensor modules  :( It may be possible to measure fan RPM via an ACPI call, but we've got no documentation on the ACPI layout of your system :(
