System Stability Test doesn't support that, but you can design a SensorPanel layout (using graphs) that can do that ;)
You can set the CPU afffinity for the AIDA64 System Stability Test (SST) if you press the Preferences button in the SST window --> General --> CPU Mask --> Manual.  You can enter the mask in a decimal or hexadecimal format (e.g. 0xFF).  Make sure to use the latest AIDA64 beta release:
http://www.aida64.com/downloads/aida64extremebuild2594k7t3njqszhzip
Yes, you gotta use a bitmask there.  So if you want to use cpu0+cpu1, then the mask has to be 3 (1+2).  If you want to use cpu0+cpu1+cpu2, then the mask has to be 7 (1+2+4).
Most AIDA64 users would want to stress the whole CPU, so the affinity configuration is only for power users.  And power users can easily handle a bitmask ;)
