When I choose it lonely in System Stability Test and press Start, it doesn't use the GPU and just reports GPU2: Started while I have only one onboard GPU  :wacko:
So I have to use FurMark everytime  :(
GPU: Intel G2020 + Intel HD Graphics (Ivy Bridge)
Two OpenCL:
OpenCL: Intel® Pentium® CPU G2020 @ 2.90GHz
OpenCL: Intel® HD Graphics
Ok, so the GPU2 is correct but it doesn't use it at all  :wacko:
Why doesn't AIDA64 use OpenGL like FurMark? Many old GPUs don't support it too =/
How can you tell it's not using the GPU?  Have you checked the CPU GT Cores power draw on the Sensor page?
OpenGL is not an option for us, simply because via OpenGL it's not possible to stress all GPUs simulatenously.  E.g. with an iGPU + discrete GPU (video card) configration, you can only use OpenGL with one of the GPUs, but not with both.  Via OpenCL you can stress every GPUs in the system.
  On 9/16/2013 at 12:21 PM, P.J said:
Nice link  :huh:
But I can't use OpenCL on older graphic cards like Mobility X300 or else while they all support OpenGL  :unsure:
Nothing is perfect, not even AIDA64's System Stability Test ;)
