CPU load still not showing properly (8700K)
Hi, for a long time and even with latest version 7.35 CPU load value of my 8700K on idle is compared to win11 taskmanager is
1. approx 4 times higher compared to task manager with activated stability/ win11 CPU util. measurement wokaround
1. approx 4 times lower compared to task manager with deactivated stability/ win11 CPU util. measurement wokaround
will there ever be a working fix or can´t this issue be solved?
  • rick11 changed the title to CPU load still not showing properly (8700K)
  • 3 weeks later...
  • 4 weeks later...
On 8/28/2024 at 5:33 AM, rick11 said:
@Fiery Is there no way to implement it so that the CPU load values are displayed exactly in sync with the Windows 11 Task Manager values, like HW-Monitor or HW-Info do?No chance to implement it the way HW-Monitor/HW-Info does it, which shows up the CPU-Load values absolutely synchron to the win11 taskmanager´s values?
im replying cause i share your frustration with aida.
for paid software its highly disappointing and frustrating the issues with correctly reporting values and the lack of actual support to fix the most basic of sensor values.
i have 7900x3d and 7900xtx, asrock mb.
my cpu % basically always says 0 unless im playing a game and the gpu load is never inline with what windows or adrenaline is reporting.
the msi psu fan rpm hops randomly between 0 and 5000 rpm and mostly sits at 0 even tho its spinning. the fan itself can only reach 2000.
hwinfo and hwmonitor reports all these sensors perfectly. can literally line them all up side by side with adrenaline and task manager and the values are all exactly the same. not aida tho, its pulling number out of right field somewhere, who knows.
once an alternate solution comes out for a hardware panel im switching. id use rainmeter but it causes random fps drops when its active. so very unfortunately stuck with aida and its incorrect reporting of basic sensors like cpu % until an alternate solution arrives.
  • 3 weeks later...
I appreciate his work very much for years and love the hardware panel, sadly there are only two options for cpu values, that doesn´t work for me:
1. without fix AIDA64 shows constantly 0 in idle, whereas taskmanager shows 3-4 %
2. with fix AIDA64 shows values in idele that are twice that high ~ 7 %
  • 4 weeks later...
