fixed: Chassis Fan #2 is not detected Asus ROG Strix B760-A Gaming WiFi
Hi,
The Chasis fan #2 of my MB is not detected by the software AIDA64, the other Chasis fan #1, #3 and #4 yes.
In armory crate is well detected, the four chasis fan are show.
Could you chek what is incorret?
Thanks!
  • Solution
  On 8/12/2024 at 10:42 AM, elgonspain said:
Hi,
Thanks!
Expand
Let me know how it works.
  • Fiery changed the title to fixed: Chassis Fan #2 is not detected Asus ROG Strix B760-A Gaming WiFi
