abramesd Posted November 1, 2024 Posted November 1, 2024 This is my configurations: AIDA64 Extreme v7.40.7100 ASRock X670e Taichi Carrara Motherboard w/ v2.10 bios AMD Ryzen 9 7950 X3D CPU 196 GB RAM The Chassis Fan #3 does not appear in the list of Chassis Fans. I am using this for the Water Flow Sensor of my water-cooling loop. At first I thought that maybe this not being a fan was the problem but after swapping Fan #4 with the flow sensor the Chassis Fan #3 is still not in the list of Fan Sensors. I open HWiNFO 64 v8.14-5580 and it lists Chassis Fan #3. Before I open a bug report on this, I thought I would ask if there was a workaround or something I needed to check first? Thank you David Quote
Fiery Posted November 11, 2024 Posted November 11, 2024 On 11/1/2024 at 2:32 PM, abramesd said: This is my configurations: AIDA64 Extreme v7.40.7100 ASRock X670e Taichi Carrara Motherboard w/ v2.10 bios AMD Ryzen 9 7950 X3D CPU 196 GB RAM The Chassis Fan #3 does not appear in the list of Chassis Fans. I am using this for the Water Flow Sensor of my water-cooling loop. At first I thought that maybe this not being a fan was the problem but after swapping Fan #4 with the flow sensor the Chassis Fan #3 is still not in the list of Fan Sensors. I open HWiNFO 64 v8.14-5580 and it lists Chassis Fan #3. Before I open a bug report on this, I thought I would ask if there was a workaround or something I needed to check first? Thank you David AIDA64 automatically hides stopped fans from the list of sensor items. Once it starts spinning, it will appear. Quote
Alungatu Posted March 5, 2025 Posted March 5, 2025 Hey! Sorry to post on this old topic, I have same problem. And Armory Crate see Fan #5.. Aida64 dont. And fan is spinning. (CHA_FAN3 is empty, thats why is missing; but 1,2 and 4,5 are connected) Quote
Fiery Posted March 6, 2025 Posted March 6, 2025 20 hours ago, Alungatu said: Hey! Sorry to post on this old topic, I have same problem. And Armory Crate see Fan #5.. Aida64 dont. And fan is spinning. (CHA_FAN3 is empty, thats why is missing; but 1,2 and 4,5 are connected) In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Fiery Posted March 9, 2025 Posted March 9, 2025 3 hours ago, Alungatu said: Any solution? The issue will be fixed in the next AIDA64 beta update. Quote
Fiery Posted March 10, 2025 Posted March 10, 2025 On 3/9/2025 at 3:17 PM, Alungatu said: Any solution? The above mentioned new AIDA64 beta update is available for download at: https://www.aida64.com/downloads/latesta64xebeta 1 Quote
Cybrdude Posted October 19, 2025 Posted October 19, 2025 Issue has returned. Last night all Chassis fans (Asus Strix X870 Gaming Wi-Fi) showed in Sensor Panel (yet visible in iCue and Armory) -- today gone. I will backup and try a clean install. Quote
MarkL Posted October 23, 2025 Posted October 23, 2025 I was going to post as well that my GPU Fans just dropped off Along with GPU temp that I was using. I did just do a Nvidia update of the latest GForce driver today. 3 fans, only showing 2, the 3rd simply disappeard from my custom panel though it is configured and GPU temp went to 0. Running AIDA64 Extreme v8.00.8000 Running a AMD 9300X3D on a Asus X870E with a EVGA RTX 3080 RTW Mark Quote
Fiery Posted November 9, 2025 Posted November 9, 2025 On 10/24/2025 at 1:23 AM, MarkL said: I was going to post as well that my GPU Fans just dropped off Along with GPU temp that I was using. I did just do a Nvidia update of the latest GForce driver today. 3 fans, only showing 2, the 3rd simply disappeard from my custom panel though it is configured and GPU temp went to 0. Running AIDA64 Extreme v8.00.8000 Running a AMD 9300X3D on a Asus X870E with a EVGA RTX 3080 RTW Mark In AIDA64 please press Ctrl+D --> Sensor Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also, in AIDA64 please press Ctrl+D --> Sensor Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Cybrdude Posted November 27, 2025 Posted November 27, 2025 Nvidia SMBus Dump ------[ Versions ]------ Program Version : AIDA64 Extreme v8.00.8026 Beta LLKD Version : 1021 BenchDLL Version: 4.7.924.8-x64 Windows Version : Microsoft Windows 11 Pro 10.0.26220.7271 (64-bit) GetProductInfo : 0x00000030 ------[ Video Adapters ]------ PNY RTX 5080 [10DE-2C02 / 196E-1432 / Rev A1] ------[ Video Driver ]------ nvldumd.dll||32.0.15.8180|||nvldumdx.dll||32.0.15.8180 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------ Total : 4.1 sec GPU1-B00: 0.3 sec GPU1-B01: 0.3 sec GPU1-B02: 0.3 sec GPU1-B03: 0.3 sec GPU1-B04: 2.6 sec nvidiasmbusdump.txt Quote
Cybrdude Posted November 27, 2025 Posted November 27, 2025 Nvidia GPU Registers ------[ Versions ]------ Program Version : AIDA64 Extreme v8.00.8026 Beta LLKD Version : 1021 BenchDLL Version: 4.7.924.8-x64 Windows Version : Microsoft Windows 11 Pro 10.0.26220.7271 (64-bit) GetProductInfo : 0x00000030 ------[ Video Adapters ]------ PNY RTX 5080 [10DE-2C02 / 196E-1432 / Rev A1] ------[ Video Driver ]------ nvldumd.dll||32.0.15.8180|||nvldumdx.dll||32.0.15.8180 ------[ nVIDIA GPU #1 @ mem D8000000 ]------ Video Adapter = PNY RTX 5080 GPU Code Name = GB203-400-A1 PCI Device = 10DE-2C02 / 196E-1432 [Rev A1] GPU Clocks = 2595 / 0 / 0 MHz Memory Clock = 15201 MHz GPU Base Clock = 13500 kHz Shader Base Clock = 13500 kHz Memory Base Clock = 13500 kHz nvidia-000000 = 1B3000A1 [GB203] nvidia-022400 = 00000000 nvidia-022430 = 00000007 nvidia-022434 = 00000006 nvidia-022438 = 00000004 nvidia-02243C = 00000004 nvidia-022440 = 00000004 nvidia-08A000 = FFFFFF8F nvidia-100714 = 00002424 nvidia-101000 = 00400080 nvidia-10100C = 02013000 nvidia-120070 = 00100401 nvidia-120074 = 00000004 nvidia-120078 = 00000007 nvidia-122634 = 00000000 nvidia-300000 = FFC00E4C nvidia-310000 = 54F0211F nvidia-700000 = 00000000 ------[ nVIDIA GPU #1 / ForceWare Properties ]------ Memory Type = 16 (GDDR7) Memory Vendor = 1 (Samsung) Memory Bank Count = 1 Memory Bus Width = 256-bit GPU / MC / VE / BI Load = 5 / 1 / 0 / 100 VPE Count = 0 Shader Pipe Count = 7 Shader SubPipe Count = 42 Total SP Count = <unknown> Total TPC Count = 0 Total SM Count = <unknown> Core Count = 10752 ROP Count = 112 Partition Count = 4 (mask: 0000000F) Fan RPM = <unknown> Fan Duty Cycle = <unknown> All Fans RPM & Duty = 0 RPM / 0 RPM / 0 % / 0 % Core Voltage = <unknown> Core Rail Voltage = 925000 uV Current Pstate = 5 PerfCap Reason = 4 (Reliability Voltage) Ventura State = <unknown> Physical Frame Buffer Size = 16693824 KB Virtual Frame Buffer Size = 16694272 KB Total / Free Video Memory = 16694272 KB / 14611080 KB ------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------ Perf. Levels = 5 Active Profile = 4 curr-core/shader/mem-0 = 180 MHz / 0 MHz / 405 MHz curr-core/shader/mem-1 = 180 MHz / 0 MHz / 810 MHz curr-core/shader/mem-2 = 225 MHz / 0 MHz / 7001 MHz curr-core/shader/mem-3 = 225 MHz / 0 MHz / 15001 MHz curr-core/shader/mem-4 = 225 MHz / 0 MHz / 15201 MHz [Active] orig-core/shader/mem-0 = 180 MHz / 0 MHz / 405 MHz orig-core/shader/mem-1 = 180 MHz / 0 MHz / 810 MHz orig-core/shader/mem-2 = 180 MHz / 0 MHz / 7001 MHz orig-core/shader/mem-3 = 180 MHz / 0 MHz / 14801 MHz orig-core/shader/mem-4 = 180 MHz / 0 MHz / 15001 MHz [Active] ------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------ Perf. Levels = 5 Active Profile = 4 curr-core/shader/mem-0 = 180 MHz / 0 MHz / 405 MHz curr-core/shader/mem-1 = 180 MHz / 0 MHz / 810 MHz curr-core/shader/mem-2 = 225 MHz / 0 MHz / 7001 MHz curr-core/shader/mem-3 = 225 MHz / 0 MHz / 15001 MHz curr-core/shader/mem-4 = 225 MHz / 0 MHz / 15201 MHz [Active] orig-core/shader/mem-0 = 180 MHz / 0 MHz / 405 MHz orig-core/shader/mem-1 = 180 MHz / 0 MHz / 810 MHz orig-core/shader/mem-2 = 180 MHz / 0 MHz / 7001 MHz orig-core/shader/mem-3 = 180 MHz / 0 MHz / 14801 MHz orig-core/shader/mem-4 = 180 MHz / 0 MHz / 15001 MHz [Active] ------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------ Perf. Levels = 1 Active Profile = 255 curr-core/mem-0 = 2805 MHz / 15201 MHz orig-core/boost/mem-0 = 2295 MHz / 2730 MHz / 15001 MHz ------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------ Perf. Levels = 1 Active Profile = 255 curr-core/mem-0 = 2662 MHz / 15201 MHz orig-core/boost/mem-0 = 2295 MHz / 2730 MHz / 15001 MHz ------[ NVAPI GPU Handles ]------ GPU Count = 1 GPU #1 = 0000000000000100 ------[ nVIDIA GPU #1 / Thermal Settings V2 ]------ Sensor Count = 1 Sensor #0 / Controller = GPU Internal Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 42 Celsius ------[ nVIDIA GPU #1 / Thermal Settings V1 ]------ Sensor Count = 1 Sensor #0 / Controller = GPU Internal Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 42 Celsius nvidiagpureg.txt Quote
Cybrdude Posted November 27, 2025 Posted November 27, 2025 On 11/9/2025 at 1:35 AM, Fiery said: In AIDA64 please press Ctrl+D --> Sensor Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also, in AIDA64 please press Ctrl+D --> Sensor Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery I pasted and attached the requested data. 🙂 Quote
Fiery Posted Saturday at 03:21 PM Posted Saturday at 03:21 PM On 11/27/2025 at 11:21 PM, Cybrdude said: I pasted and attached the requested data. 🙂 Thank you for the data! Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
